AutoCAD Raster Design Forum
2D RUBBER SHEET
1 REPLY 1
493 Views, 1 Reply
2D RUBBER SHEET
HI ALL
I HAVE A PROBLEM WHEN I USE RUBBER SHEET ALL MY POLY LINES ELEVATION CHANE IN TO DIFFERENT VALUE
I EVEN USE SOME BASE AND REFERENCE POINT BY 0 (ZERO) ELEVATION BUT THE ELEVATION OF OBJECT DIFFFER AFTER RUBBER SHEET
PLEASE HELP
WHAT SHOULD I DO TO DO 2D RUBBER SHEET ?
PLEASE
1 REPLY 1
That's the way "rubber" sheet works by design. When you pull or stretch in
one direction it will shrink or push in the other direction just like a
piece of rubber. Try using the align command or see if setting osnapz = 1
works any better.
Murph
http://map3d.wordpress.com/
"maxicosi" wrote in message news:6285517@discussion.autodesk.com...
HI ALL
PLEASE HELP
PLEASE
”Boost
