AutoCAD Raster Design General Discussion
New Member
maxicosi
Message 1 of 2 (253 Views)
2D RUBBER SHEET
253 Views, 1 Replies
11-09-2009 12:21 AM
HI ALL
I HAVE A PROBLEM WHEN I USE RUBBER SHEET ALL MY POLY LINES ELEVATION CHANE IN TO DIFFERENT VALUE
I EVEN USE SOME BASE AND REFERENCE POINT BY 0 (ZERO) ELEVATION BUT THE ELEVATION OF OBJECT DIFFFER AFTER RUBBER SHEET
PLEASE HELP
WHAT SHOULD I DO TO DO 2D RUBBER SHEET ?
PLEASE
*Murph
Message 2 of 2 (253 Views)
Re: 2D RUBBER SHEET
11-09-2009 05:53 AM in reply to: maxicosi
That's the way "rubber" sheet works by design. When you pull or stretch in
one direction it will shrink or push in the other direction just like a
piece of rubber. Try using the align command or see if setting osnapz = 1
works any better.
Murph
http://map3d.wordpress.com/
"maxicosi" wrote in message news:6285517@discussion.autodesk.com...
HI ALL
PLEASE HELP
PLEASE
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
