We are using images from a Satellite Imagery company. The TIFF image is around 6 megs in size and after trying to use the image embed command from the raster image the command line reads "1 image(s) filtered out, 0 image(s) embedded". We've looked at most of the commands and can't find a solution. Any help would be appreciated.
late post,,,,try making a new layer 'tif' and the color white, put your .tif file on this layer...when u do the iembed command it should not say there was any filtered out,,,,just one embedded...if it does delete the .tif and check ur xref manager an detach...start over inserting .tif file and put on tif layer,,iembed should work then.
did you get a solution for this issue? I am getting the same error "1 image(s) filtered out, 0 image(s) embedded"
