AutoCAD Raster Design Forum
2011 AutoCAD Raster Image Embed problem?
4 REPLIES 4
ges87401
3883 Views, 4 Replies
We are using images from a Satellite Imagery company. The TIFF image is around 6 megs in size and after trying to use the image embed command from the raster image the command line reads "1 image(s) filtered out, 0 image(s) embedded". We've looked at most of the commands and can't find a solution. Any help would be appreciated.
4 REPLIES 4
Rainman1
in reply to: ges87401
Try inserting the image into Microsoft Word first and then copy and paste from Word to AutoCAD.
jedenton
in reply to: Rainman1
late post,,,,try making a new layer 'tif' and the color white, put your .tif file on this layer...when u do the iembed command it should not say there was any filtered out,,,,just one embedded...if it does delete the .tif and check ur xref manager an detach...start over inserting .tif file and put on tif layer,,iembed should work then.
Not working for me.
did you get a solution for this issue? I am getting the same error "1 image(s) filtered out, 0 image(s) embedded"
”Boost
