AutoCAD R12/R13/R14 Archive (Read Only)
Text with a white background
9 REPLIES 9
Message 1 of 10
atjohnson124
28721 Views, 9 Replies
I am placing text above raster images and other external refrences. It is hard to see the text, so I am trying to put a white box behind it. Adding another refrence (for the white box) is too much hassle. A friend of mine recalls a text command that allows you to do this.
I am using r14.
9 REPLIES 9
Message 2 of 10
in reply to: atjohnson124
WIPEOUT, perhaps (an Express Tool)?
__
"atjohnson124" wrote in message
news:f09af8f.-1@WebX.maYIadrTaRb...
> I am using r14.
Message 3 of 10
Or TEXTMASK (which uses a wipeout object)...
___
"Paul Turvill" wrote in message
news:CA13706DCAB396FAAA09EB77C2D8C1AE@in.WebX.maYIadrTaRb...
> __
is
> > I am using r14.
Message 4 of 10
JamaL9722060
I have the same issue but I’m using AutoCAD 2013,
All what I need is a no color or white background for the text such that the background will hide whatever below it
Sounds that AutoCAD doesn’t have white color or no color option
In case of dimensions, this is quite simple!
How this issue might be handled?
Best
Jamal
Jamal Numan
Message 5 of 10
steven-g
in reply to: JamaL9722060
Yes it does, pick the last option 'select color' from the drop down in the background mask dialogue, that should open up the standard color pick options, and you can choose white from that, or tick the option for 'use drawing background color'
Message 6 of 10
JamaL9722060
in reply to: steven-g
Many thanks Steven,
  • Providing white color background will provide it as black (as the background of my display is chosen to be white)
  • Then I think that the only option I have is to tick the option “use drawing background color” as you have already advised
  • How to apply this option at the style level! I couldn’t find this option there!
  • How to apply this background for an EXISTING attribute definition (living within a block)
Best
Jamal
Jamal Numan
Message 7 of 10
steven-g
Take a look at this http://www.cadtutor.net/forum/showthread.php?24298-Attribute-w-Background-Mask
it will mean editing your blocks but should get you the results you want
Message 8 of 10
JamaL9722060
Many thanks steven-g.
The link you have already sent solved part of my question
  1. How to give the text style a particular background?
  1. How to give the leader text a background?
Jamal Numan
Message 9 of 10
steven-g
As far as I can see there is no way to add background color in the text style itself. It may be worth asking in the LISP forum to see if anyone there could help you.
Message 10 of 10
JamaL9722060
Many thanks steve. I did
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
best
Jamal
Jamal Numan
