Image command restored! Hope this helps someone. I am running AutoCAD R.14 on Windows Vista Home 32bit, and it seems successful so far. I renamed the SH31W32.dll file located in the AutoCAD root directory, replaced with the modified download from Ed S. post dated 5-14-07 on this thread and did also loose my "Image" command. My fix for this was trial and error in that I opened AutoCAD R.14 and restored down the program window in order to see my Windows Desktop. I had placed an image file in the form of a .jpg on my Desktop, which I then attempted to drag-n-drop onto my drawing screen as a test. An error will occur at first, but once you cancel this first message the "Image" command should be restored from then on.
