AutoCAD R12/R13/R14 Archive (Read Only)
Moving currently running instance of R13 to Windows 95 VM.
3 REPLIES 3
NonAutoCADUser
1421 Views, 3 Replies
Hello everyone.  There is a long story and there is a short story.  🙂  Here is the short story version.
My client has an instance of R13 on his Windows 95 system and CDs are corrupted and no other CDs around with R13. I have copied over the installed directories from the physical 95 system to the Windows 95 VM I created and encounter some errors and I need a clean running instance, just like it running on the current box.  My Win 95 VM instance runs flawlessly.  I am only having issues with the R13 folders that I simply copied over.  Could someone help me identify the solution(s) with the errors I'm running into?
Thanks.
craig
3 REPLIES 3
You're probably missing some dll files from the orginal Windows/System directory
Are getting any error message such as 'Missing MS......DLL'
Video and mouse drivers can also be a pain with Virtual Machines
-David
Hello David.  Thanks for responding so fast.
No, I'm not getting any missing .dll pop ups.  I grabbed some screen shots of the error happening.  I'm attached an Errors.pdf file.
Thanks for your help.
craig
Have you or can run _.config ?
Or, run acad.exe -r from the command line.
My guess is that the configio error is either video or keboard / pointer invalid configurations.  -David
