I get a similar message about once per month on R-12 whenever I have lottsa XREF's in one drawing. Quite possibly I often have one XREF'd drawing, which includes one or two more whithin that. Then find that one of the sub-sub drawings has a problem in it. Possibly a reference to another drawing already in the biggie parent drawing, creating a circular reference.
If I do a simple PURGE to the sub file it often clears it up. On occasion I have to go into recovery mode. But this problem is only because I tend to XREF in quite a few separate ones into the final drawing. If you are not, it may not be same thing.
It will sometimes kick me out time after time, until the bad drawing is located.
Wm.
