I am trying to create mask for litographic process which has to be stored in dxf file (it is my first time facing this file). The mask looks pretty simple, it contains just black solid lines followed by white spaces. First I have created EPS file and export it using pstoedit utility to dxf file (pstoedit -f "dxf" .input.eps > output.dxf). Everything works just fine (it seems to...), but the solid black lines (it is more like rectangle) are not filled. I have been trying to edit dxf file directly using specifications but without any success. If I create filled pattern in inkscape, for instance, and save it as dxf file, it is not filled as well.
Ok, It could be, that my reader (QCad) does not show it properly...
Here is that dxf file (just an example):
999
DXF created by Inkscape
0
SECTION
2
HEADER
9
$ACADVER
1
AC1014
9
$HANDSEED
5
FFFF
9
$MEASUREMENT
70
1
0
ENDSEC
0
SECTION
2
TABLES
0
TABLE
2
VPORT
5
8
330
0
100
AcDbSymbolTable
70
4
0
VPORT
5
2E
330
8
100
AcDbSymbolTableRecord
100
AcDbViewportTableRecord
2
*ACTIVE
70
0
10
0.0
20
0.0
11
1.0
21
1.0
12
210.0
22
148.5
13
0.0
23
0.0
14
10.0
24
10.0
15
10.0
25
10.0
16
0.0
26
0.0
36
1.0
17
0.0
27
0.0
37
0.0
40
341.0
41
1.24
42
50.0
43
0.0
44
0.0
50
0.0
51
0.0
71
0
72
100
73
1
74
3
75
0
76
0
77
0
78
0
0
ENDTAB
0
TABLE
2
LTYPE
5
5
330
0
100
AcDbSymbolTable
70
1
0
LTYPE
5
14
330
5
100
100
AcDbLinetypeTableRecord
2
BYBLOCK
70
0
3
72
65
73
0
40
0.0
0
LTYPE
5
15
330
5
100
100
2
BYLAYER
70
0
3
72
65
73
0
40
0.0
0
LTYPE
5
16
330
5
100
100
2
CONTINUOUS
70
0
3
Solid line
72
65
73
0
40
0.0
0
ENDTAB
0
TABLE
2
LAYER
5
2
100
AcDbSymbolTable
70
2
0
LAYER
5
50
100
100
AcDbLayerTableRecord
2
0
70
0
6
CONTINUOUS
0
LAYER
5
51
100
100
2
ink_ext_XXXXXX
70
0
6
CONTINUOUS
0
ENDTAB
0
TABLE
2
STYLE
5
3
330
0
100
AcDbSymbolTable
70
1
0
STYLE
5
11
330
3
100
100
AcDbTextStyleTableRecord
2
STANDARD
70
0
40
0.0
41
1.0
50
0.0
71
0
42
2.5
3
txt
4
0
ENDTAB
0
TABLE
2
VIEW
5
6
330
0
100
AcDbSymbolTable
70
0
0
ENDTAB
0
TABLE
2
UCS
5
7
330
0
100
AcDbSymbolTable
70
0
0
ENDTAB
0
TABLE
2
APPID
5
9
330
0
100
AcDbSymbolTable
70
2
0
APPID
5
12
330
9
100
100
AcDbRegAppTableRecord
2
ACAD
70
0
0
ENDTAB
0
TABLE
2
DIMSTYLE
5
A
330
0
100
AcDbSymbolTable
70
1
0
DIMSTYLE
105
27
330
A
100
100
AcDbDimStyleTableRecord
2
ISO-25
70
0
3
4
5
6
7
40
1.0
41
2.5
42
0.625
43
3.75
44
1.25
45
0.0
46
0.0
47
0.0
48
0.0
140
2.5
141
2.5
142
0.0
143
0.03937007874016
144
1.0
145
0.0
146
1.0
147
0.625
71
0
72
0
73
0
74
0
75
0
76
0
77
1
78
8
170
0
171
3
172
1
173
0
174
0
175
0
176
0
177
0
178
0
270
2
271
2
272
2
273
2
274
3
340
11
275
0
280
0
281
0
282
0
283
0
284
8
285
0
286
0
287
3
288
0
0
ENDTAB
0
TABLE
2
BLOCK_RECORD
5
1
330
0
100
AcDbSymbolTable
70
1
0
BLOCK_RECORD
5
1F
330
1
100
100
AcDbBlockTableRecord
2
*MODEL_SPACE
0
BLOCK_RECORD
5
1B
330
1
100
100
2
*PAPER_SPACE
0
ENDTAB
0
ENDSEC
0
SECTION
2
BLOCKS
0
BLOCK
5
20
330
1F
100
AcDbEntity
8
0
100
AcDbBlockBegin
2
*MODEL_SPACE
70
0
10
0.0
20
0.0
30
0.0
3
*MODEL_SPACE
1
0
ENDBLK
5
21
330
1F
100
AcDbEntity
8
0
100
AcDbBlockEnd
0
BLOCK
5
1C
330
1B
100
AcDbEntity
67
1
8
0
100
AcDbBlockBegin
2
*PAPER_SPACE
1
0
ENDBLK
5
1D
330
1B
100
AcDbEntity
67
1
8
0
100
AcDbBlockEnd
0
ENDSEC
0
SECTION
2
ENTITIES
0
LINE
5
100
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
10.352816
30
0.0
11
110.352946
21
10.352816
31
0.0
0
LINE
5
101
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
10.352816
30
0.0
11
110.352946
21
20.352831
31
0.0
0
LINE
5
102
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
20.352831
30
0.0
11
10.352793
21
20.352831
31
0.0
0
LINE
5
103
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
20.352831
30
0.0
11
10.352793
21
10.352816
31
0.0
0
LINE
5
104
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
10.352816
30
0.0
11
10.352793
21
10.352816
31
0.0
0
LINE
5
105
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
30.352846
30
0.0
11
110.352946
21
30.352846
31
0.0
0
LINE
5
106
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
30.352846
30
0.0
11
110.352946
21
50.352877
31
0.0
0
LINE
5
107
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
50.352877
30
0.0
11
10.352793
21
50.352877
31
0.0
0
LINE
5
108
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
50.352877
30
0.0
11
10.352793
21
30.352846
31
0.0
0
LINE
5
109
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
30.352846
30
0.0
11
10.352793
21
30.352846
31
0.0
0
LINE
5
10a
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
70.352731
30
0.0
11
110.352946
21
70.352731
31
0.0
0
LINE
5
10b
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
70.352731
30
0.0
11
110.352946
21
80.352746
31
0.0
0
LINE
5
10c
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
80.352746
30
0.0
11
10.352793
21
80.352746
31
0.0
0
LINE
5
10d
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
80.352746
30
0.0
11
10.352793
21
70.352731
31
0.0
0
LINE
5
10e
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
70.352731
30
0.0
11
10.352793
21
70.352731
31
0.0
0
LINE
5
10f
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
100.352953
30
0.0
11
110.352946
21
100.352953
31
0.0
0
LINE
5
110
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
100.352953
30
0.0
11
110.352946
21
120.353125
31
0.0
0
LINE
5
111
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
120.353125
30
0.0
11
10.352793
21
120.353125
31
0.0
0
LINE
5
112
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
120.353125
30
0.0
11
10.352793
21
100.352953
31
0.0
0
LINE
5
113
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
100.352953
30
0.0
11
10.352793
21
100.352953
31
0.0
0
LINE
5
114
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
130.353175
30
0.0
11
110.352946
21
130.353175
31
0.0
0
LINE
5
115
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
130.353175
30
0.0
11
110.352946
21
140.353191
31
0.0
0
LINE
5
116
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
110.352946
20
140.353191
30
0.0
11
10.352793
21
140.353191
31
0.0
0
LINE
5
117
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
140.353191
30
0.0
11
10.352793
21
130.353175
31
0.0
0
LINE
5
118
100
AcDbEntity
8
ink_ext_XXXXXX
62
7
100
AcDbLine
10
10.352793
20
130.353175
30
0.0
11
10.352793
21
130.353175
31
0.0
0
ENDSEC
0
SECTION
2
OBJECTS
0
DICTIONARY
5
C
330
0
100
AcDbDictionary
3
ACAD_GROUP
350
D
3
ACAD_MLINESTYLE
350
17
0
DICTIONARY
5
D
330
C
100
AcDbDictionary
0
DICTIONARY
5
1A
330
C
100
AcDbDictionary
0
DICTIONARY
5
17
330
C
100
AcDbDictionary
3
STANDARD
350
18
0
DICTIONARY
5
19
330
C
100
AcDbDictionary
0
ENDSEC
0
EOF
Any idea how to fill those rectangles?
Thanks a lot.
Radek
