AutoCAD R12/R13/R14 Archive
Patchy
Message 11 of 23 (1,245 Views)
Re: Downloading problems for 3rd party hatch patterns.
02-08-2011 08:30 PM in reply to: Patchy
Keep them separate, right on :manwink:, why do people edit the acad.pgp ?
*Pro
Modman_4
Message 12 of 23 (1,239 Views)
02-09-2011 05:18 AM in reply to: Patchy
OP what happens if you type OPTIONS on the command line?
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
pendean
Message 13 of 23 (1,233 Views)
02-09-2011 09:48 AM in reply to: Patchy
>>>...Who doesn't back up regularly?...<<<
Good one :smileyhappy:
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
pendean
Message 14 of 23 (1,234 Views)
02-09-2011 09:50 AM in reply to: Patchy
If the program offered another choice it would be used instead: you can't fancy-talk out of this, there is no correct or wrong way, just better ways and harder ways of doing things.
Patchy
Message 15 of 23 (1,229 Views)
02-09-2011 10:57 AM in reply to: Patchy
:smileyvery-happy: :smileyvery-happy: :smileyvery-happy:
kenrmer
Message 16 of 23 (1,227 Views)
02-09-2011 11:16 AM in reply to: Patchy
With ACLT 98 when typing "OPTIONS" on the command line, reply is "UNKNOWN COMMAND"`.
kenrmer
Message 17 of 23 (1,223 Views)
02-09-2011 11:55 AM in reply to: Patchy
Patchy, as requested here is an attachment with the Culture Stone Drystack hatch pattern installed in the Bhatch file. Saved it as a txt file. The cs_drystack is loaded after the last predefined hatch pattern ZIGZAG. Remember, I'm running ACLT98. I tried typing "options' in the command line and the response is "Command Not Found". When I go to Bhatch from the pull down tab I get the predefined patterns only, nothing in user-defined nor custom. When I click on custom, the custom pattern box becomes active with the last used predefined default pattern name still visible but....greyed out in the box just above. When I type in "cs_drystack"  into the custom box, the response is "unknown pattern name".
Patchy
Message 18 of 23 (1,221 Views)
02-09-2011 12:07 PM in reply to: Patchy
Everything looks good, except you forgot to put a ; (semicolon) at the last line of the file.
Just put one ;  by itslef and it should work
Like this:
45,34.826,21.8,27.0910285542,27.0910285542,0.54182,-53.6402371084
135,4.5592,23.715,27.0910285542,27.0910285542,0.54182,-53.6402371084
45,27.968,30.995,27.0910285542,27.0910285542,0.54182,-53.6402371084
0,27.547,1.4942,0,38.3125,1.9539,-36.3586
kenrmer
Message 19 of 23 (1,212 Views)
02-09-2011 02:14 PM in reply to: Patchy
Ok, added the semi-colon after the last line. Saved it, closed down, rebooted, reopened a dwg file, and...nothing changed. Rechcecked the aclt.pat file and the semi-colon is still there. No cs_drystack hatch pattern. Nothing in the custom category, nor predefined nor user-defined. Tried typing in "cs_drystack" in the custom pattern...reply is "no known pattern".
I even took out the space between the last predefined hatch pattern and the cs_drystack hatch pattern...no change.
This is the only copy of the AutoCAD LT98 on this computer, so it can't be due to multiple  programs.
I signed up with Culture Stone support last Friday. Still waiitng for administrator approval to sign in. Maybe they have an answer.
Patchy
Message 20 of 23 (1,209 Views)
02-09-2011 02:35 PM in reply to: kenrmer
Do this for me, at the command line type in:
(findfile "aclt.pat")           with the brackets like that, what does it prompt after you hit enter.
