AutoCAD R12/R13/R14 Archive (Read Only)
diameter dimensioning
2 REPLIES 2
325 Views, 2 Replies
an undesired change has occured in my acad-please help me to turn it back. the diamter and radius dimension looked always like a leader with a segment of horizontal line and horizontal text now it looks like a line with two arrows inside or outside the circle ant text in direction with the dimension line. think i tried to change everything possible in the dimstyle dialog box without success. thank for your kind assistance zvi
2 REPLIES 2
Hi zvi,
I've attached a .jpg to show you the problem. In Dim Styles, Format button, Text (make sure "Outside Horizontal" is checked. The circle I show has what you have and what you want. Then you will return to what you had. GL
thanks,it works zvi "madcadd" wrote in message news:7716971.1084542620171.JavaMail.jive@jiveforum2.autodesk.com... > Hi zvi, > > I've attached a .jpg to show you the problem. In Dim Styles, Format button, Text (make sure "Outside Horizontal" is checked. The circle I show has what you have and what you want. Then you will return to what you had. GL
