AutoCAD R12/R13/R14 Archive (Read Only)
Dialog Control File issues
1 REPLY 1
akid1704
663 Views, 1 Reply
Yes, I acquired a CD from a local moulding mfg which contains moulding CAD drawings.  I wanted to open these up in AutoCAD14 but cannot because each time I click on a particular moulding drawing, the AutoCAD program opens with this Error Message: Error Loading Dialog Control File.
I've checked the Support files for the Dialog Control file but cannot locate that file. Can this file be downloaded from AutoDesk? How do I load it if it is missing?
1 REPLY 1
Patchy
in reply to: akid1704
Did you copy the drawings to your PC and open it ?
