AutoCAD R12/R13/R14 Archive
Active Member
MalSikes
Message 11 of 20 (400 Views)
Re: Can't boot up rev 12
11-17-2010 05:03 PM in reply to: MalSikes
I am strictly using DOS.
I try to launch Autocad from the command prompt or the Dosshell and get the same results.
easymike299
Message 12 of 20 (394 Views)
11-18-2010 08:27 AM in reply to: MalSikes
On the odd chance that your acad.dcl file is corrupt, try this one. Don't forget there may be two instances, one in the acad directory and one in the support directory. Replace them both.
Gne
Active Member
MalSikes
Message 13 of 20 (393 Views)
11-18-2010 09:04 AM in reply to: MalSikes
The computer loads into a program called Point and Shoot. From there I can goto the DOSSHELL, Windows, or other sub directories and programs.
easymike299
Message 14 of 20 (390 Views)
11-18-2010 09:41 AM in reply to: MalSikes
Download a Dos 6.22 boot disk here .... ...
http://www.bootdisk.com/bootdisk.htm
Use it to boot your computer and see if Autocad will then run.
Gene
Active Member
MalSikes
Message 15 of 20 (387 Views)
11-18-2010 11:48 AM in reply to: MalSikes
I boot up on DOS onto a program called Point and Shoot which allows me to choose Dosshell, Windows, Autocad etc.
Active Member
MalSikes
Message 16 of 20 (384 Views)
11-18-2010 11:52 AM in reply to: easymike299
Thanks. I'll give them a try and post the results.
easymike299
Message 17 of 20 (384 Views)
11-18-2010 12:11 PM in reply to: MalSikes
What I'm suggesting is that you not use Point and Shoot but rather boot with a Dos 6.22 boot disk and run autocad from there.
If you are not successful then I'm out of ideas.
Gene
Active Member
MalSikes
Message 18 of 20 (372 Views)
11-19-2010 12:52 PM in reply to: MalSikes
EUREKA  I've done it. Thanks for all your help Gene. When I set up the computer to run Autocad I changed monitors. Everything worked fine on the monitor but I couldn't boot up Autocad. I remembered it had a monitor configuration on setup but thought they were the same. Just to confirm that was not the problem I installed my old monitor and auto cad came up just fine.
Now I can get back to drawing. Thanks Again
Mal
easymike299
Message 19 of 20 (368 Views)
11-19-2010 04:02 PM in reply to: MalSikes
All's well that ends well.
Gene
easymike299
Message 20 of 20 (340 Views)
11-26-2010 11:28 AM in reply to: easymike299
It's possible to access R12 for Dos through a window in Win3.1
I can post instructions if anyone  is interested.
Gene
