AutoCAD R12/R13/R14 Archive
New Member
bgregg
Message 1 of 2 (54 Views)
CAD 14 installation on Windows 98
54 Views, 1 Replies
11-04-2002 01:53 AM
I am trying to install AutoCAD 14 on a Windows 98 machine. I have tried both the typical install and a full install on the C:\drive. The installation appears to be normal but after restarting the machine and opening the shortcut to AutoCAD 14 I recieve the following message "Fatal Error: Security system (hardware lock or network license) in not functioning or is improperly installed" After checking the knowledge base, I have downloaded and installed the most current Sentinel Driver(version 5.41)but still get the same fatal error message. I am not doing a network version but trying to load on a individual machine.
If anyone has some advice or suggestions on how to correct this problems, please let me know. I currently have AutoCAD 14 running on several Windows 95 computers with no problems.
thank you,
Bettylynne Gregg
Sycamore High School Technology Coordinator
*Lincoln, Tracy W.
Message 2 of 2 (54 Views)
Re: CAD 14 installation on Windows 98
11-04-2002 02:20 AM in reply to: bgregg
Search this discussion group or go to the and use R14 Windows 98 as
keywords... this has been covered in quite a few threads here.
Is this the Technical Solution you read?
Error: Security system ... is not functioning or improperly installed
http://support.autodesk.com/getdoc.asp?id=TS36162
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Announcements
Need installation help?
