Ricky,
I believe the following procedure will load your arx apps automatically. All
you need is a file in your autocad support directory that is named ACAD.RX.
In the ACAD.RX file you have to supply the file path and arx name. Just use
a text editor to create it, but make sure it has a .RX extension.
ie.
c:\lsp\BigLyr14
c:\lsp\fpath14
Goodluck
Peter Ng
"Ricky M. Medley" wrote in message
news:894AC14543A7FD7086FBE9C9816CA658@in.WebX.maYIadrTaRb...
> How do you make an ARX load automatically, each time that Acad is started?
> If it is just a setting from within Acad; What file does it effect, so
that
> I can simply copy that file to multiple workstations
> If it is a script or lisp.....I don't know how to write them...
> Ricky M. Medley
> Network Administrator
> Document Control Manager
> IDS Engineering
> 600 Century Plaza Dr. Bldg. 140
> Houston, TX 77073
