AutoCAD R12/R13/R14 Archive (Read Only)
Adding a set of numbers in Autocad
3 REPLIES 3
4543 Views, 3 Replies
I used to be able to select a set of random numbers on the Autocad drawing screen and add them by using a simple command called ADD.
This was in the earlier versions of Cad R12 and the like.
I'm not sure if it was a special lisp routine or if it was part of the package.
The command worked as follows:
1. type the "add" command on the command line.
2. Select the numbers in the drawing area.
3. Press enter and you get a sum.
Does anyone know how i can do this simple thing in Autocad 2010?
I know it is a very simple thing but when adding a lot of figures all the time it does save lots of time.
3 REPLIES 3
There never was such a command in AutoCAD, it's always been an add-on Lisp.
http://www.google.com/search?q=add+numbers+in+autocad&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7HPND_en
Dean Saadallah
http://LTisACAD.blogspot.com
Do you perhaps have the lisp routine written down somewhere / can you point me in a direction to find it.
That long wordy google link did not grab your attention at all?
Dean Saadallah
