Brews wrote:
> Does anyone know how to re-enter authorisation codes for Acad 14? An
> error message will sometimes appear stating that the authorisation has
> been lost. (Without, of course, bringing up any dialog box.) The only
> solution I found so far was to uninstall and re-install, which is
> rather unpleasant. Any help would be greatly appreciated.
I believe you can edit the properties of the Windows Start-Up Shorcut's
Target and put a /r at the end of the command string.
e.g.: Target: "C:\Program Files\AutoCAD 2002\acad.exe" /r
And of course you would want to take that out after reconfiguring.
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
