this might not however work if you use a batch file (as you must) to start
AutoCAD. There might be a line in the batch-file saying set
acadcfg=c:\acad\cfg or some such. The way to go is to find the batchfile you
use, open it in an editor and look for the line where acad.exe is called.
Check that the line looks something like this:
c:\acad\acad.exe %1
Make sure thet the %1 is there. Then call this batchfile (say its called
goacad.bat) like this:
goacad -r
This will make the configuration changes to the right place.
Hope you copied the batchfiles from the old pc?
HTH
Petri Ahava
CAD-Q Finland
"Alan Langston"
wrote in message
news:f070366.1@WebX.maYIadrTaRb...
> Sorry, should be ACAD -r
