AutoCAD Plant 3D Forum
Xref Equipment can only snap to node?
3 REPLIES 3
thebearjed
570 Views, 3 Replies
this is a wierd one. i took some 3D solids and converted them to equimpent in Plant 3D (2013). when i xref them and try and dimnension them in paper space i can only snap to the nodes and not to any of the geometry snaps line center or endpoint. i am stummped.
3 REPLIES 3
Rich.O.3d
in reply to: thebearjed
Ive been doing mech stuff for the last 6 months so my plant is a tiny bit rusty
I do remember having this issue
Try making sure your in 3dwireframe not just 2dwireframe
also look at the 3dsanps
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
thebearjed
in reply to: Rich.O.3d
neither worked :(...any other ideas?
Dan.Scales
Could you upload an example drawing that can be tested with?
Dan
Dan Scales
”Boost
