It still seems to be the case in the 2012 version (for instance text is filtered out).
Can someone confirm this is the case or am i doing something wrong?
Roy
If you had attach the xRef like "overlay" is don't display, but if you attach like "Attachment type" in this case will be visible.
Hi Yury,
I tried your suggestion but unfortunately it ends up the same...
Thanks for replying ,
Roy
Is the 2D xref part of the project, or you just XREF'd a 2D file? See if it works ok by adding it to the project first.
Right click on the Model's folder, and select "copy drawing to project"
Hi
The solution seems to be:
1. Add the 2D drawing to the project
2. when setting up the Ortho view, you need to select 3D models to include...."3D model selection". Select the 2D background as one of the 3D models
3. when you update the view. ... it should show
Good luck
