AutoCAD Plant 3D General DIscussion
Active Contributor
richard.imrie
Message 1 of 3 (172 Views)
Wye Tee Iso
172 Views, 2 Replies
08-14-2013 03:22 AM
Having a bit of bother with a custom symbol for wye tees. I have created the block and all ports align with their respective ports on the iso, however one leg of the tee doesn't seem to strech to meet the port. See below clips of my block configuration and my output iso. Any suggestions?Wyeblock.png
Product Support
Dan.Scales
Message 2 of 3 (145 Views)
Re: Wye Tee Iso
08-15-2013 05:24 AM in reply to: richard.imrie
Could you test with Extension 1 loaded and let me know the result?
If the problem still occurs try using the standard Tee isometric symbol.
Dan
Dan Scales
Active Contributor
richard.imrie
Message 3 of 3 (142 Views)
Re: Wye Tee Iso
08-15-2013 05:45 AM in reply to: Dan.Scales
Spoiler
Dan,
I have extension 1 installed on my machine already. The problem you are seeing is iso's produced with the most up-to-date version of Plant.
I have also used the normal tee block to produce the wye symbol with no luck.
Furthermore, i found that a hotfix was released for 2013 to correct wye's on isometrics.Maybe this hasn't been brought forward to 2014?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
