AutoCAD Plant 3D Forum
Wrong Bolt Length when connecting to flanged nozzle
2 REPLIES 2
followsea
552 Views, 2 Replies
When connecting to flanged nozzle of an equipment that converted from autocad objects/blocks, P3D does not give bolt length correctly.
Compare following  2 examples:
1. If the quipment is created from Plant 3d parametric shapes, the bolt length is correct( P3D recalculated the bolt length  according to each "Flange Thickness" value).
2. If the equipment is converted from Autocad objects/blocks, the bolt length is NOT correct( P3D does not recalculated the bolt length  according to each "Flange Thickness" value. The bolt length remains the value in catalogue).
This problem has bothered me and our company for a long time. So many boltsets  in the BOM must be modified by hand!
Is it a bug?
PS: Searched the forum, I found that the same issue was posted more than a year ago, but no reply.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Bolt-length-on-Equipment-Flanged-Nozzle-Issue/m-p/357...
2 REPLIES 2
dave.wolfe
in reply to: followsea
Last I checked the bolt length calcs still need some work done on them. Autodesk is aware of the issue.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
kfm.yong
I have the same problem now, any new updates?
”Boost
