AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Workflow slows down 2015
1 REPLY 1
207 Views, 1 Reply
In 2015 version, when adding a certain amount of pipelines in a 3D file, gradually when the number of pipes increases, the selection pick-box freezes for a second or so when it slides on top of a pipeline or after selecting any pipe component. This freezing time increases while adding more and more pipes to the 3D, which end up being very time consuming.
We tried it in two different drawings in a couple of computers, also creating new projects and end up with the same result.
This didn’t happen in earlier version, seems to have something to do with the new selection mode.
AutoCAD Plant3D 2015 SP1
Main Board: ASUS RAMPAGE IV EXTREME
Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz 3.60 GHz
RAM: 32,0 GB
Main System SSD - Gen3 SSHD Technology - Intel 510 Series
Windows 7 Professional 64 bits
NVIDIA Quadro K5000
1 REPLY 1
quentin.contreras
Have you tried to adjust you video hardware acceleration? Follow this link located in the Autodesk Knowledge Network that explains how to do this.
How to enable or disable hardware acceleration in AutoCAD
Also, check and adjust SELECTIONEFFECT.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
”Boost
