I turn to say the same like in the previous wish lists, and I hope that the developer team will help:
- Cable Trays for Plant 3D! It's imposible to design Industry Plant without this component.
- Better Ortho generation: auto dimensions, auto anotation, view hide pipes,...
- Any basic civil modelation (e.g. walls in 3D with special hatch pattern in ortho)
- Better structural modelation (the same like in Structural Detailing)
- Better P&ID integration on 3D, e.g. equipment list P&ID in 3D for insert it
Those functions now exist in AutoCAD MEP and Structural Detailing, I think that it will be good solution to integrate the same in Plant3D and convert it in the best Plant software. Because the integration between ASD, Plant3D and MEP it's not good, is not posible have all objects in the same database. It will be better, to have all Plant solutions in the same softare and in the same database, where with one changing workspace you can design: structural, cable trays, pipes, civil, and after this generate ortho views with all details automatically, generate list of material,...
For Plant Design Suite:
- Add in ultimate suite the Robot for calculation of structure (the same like in building design suite 2013)
With those changes the Plant3D will accelerate it integration in industry, and in few time will be the best and more usefull.
-It would be nice be to have the option to import a linelist from an Excel-spreadsheet into Plant 3D and then use this list to route piping. I would like it to work the same way the P&ID Linelist works but without having to create an actual P&ID.
-Hatching in orthographic drawings
My overall impression of Plant 3D is okay, I think it will be a good program in a few releases. If you were starting off using a piping package and are not doing anything outside the norm then it is fine. I hope the Plant 3D development team take note of what the users are asking for and incorporate these them in release 2014 and later.
For us we are going to revert back to CadWorx for the next project and since it will be my responsibility to get the drawings out the door I am delighted.
A few comments:
The final straw came when using Plant 3D.
Isometrics:
Isometric drawing sheet set up:
Specs and Catalogs:
Discussion Groups:
Excellent resource, I would have been lost without them, the users have solved most of the problems I was having.
-Better library of pipe support and attachment databases
-MTO report (via Report creator & database manager) to display units of measurement particularly for fittings and boltings
@PatrickByrne wrote:
Discussion Groups:
Nice Post Patrick. I too find Forums / Discussion Groups to be a wealth of information.
There is also a CADWorx discussion forum, not sure if you are aware.
Edited by
Discussion_Admin
Hi balbs29,
We have not released AutoCAD Plant 3D 2014 yet. However if you want to download the 2013 version, you can do so via our Trial Version page.
1. When a pipe is selected, it would be nice to have the T.O.P./C.O.P./B.O.P (maybe even T.O.I./B.O.I) listed in the properties palette for easy entry/changing. Currently clicking the little arrow when the pipe is selected and "tabbing" to either T.O.P./C.O.P./B.O.P works, but sometimes they are out of the current zoom level view or are stacked on top of each other.
2. Showing insulation as a seperate component in navisworks that could possibly be selected and given a transparency. Currently I trace my pipe lines with a 3Dpolyline then sweep a circle with a diameter of the insulation. This is a workaround but if i change my pipe, editing the swept solid is a bit of a pain.
3. A better workflow for exporting/importing Plant3D models into Revit. Unless there is a way that I havent read about. Currently, whether I have the Revit link in the Plant3D dwg or an export using Exporttoautocad, Revit "sees" all the facets that make up the solids. So trying to make Plan/Section drawings of equipment or pipe in Revit looks very odd/messy.
4. Revise/check the dimensions of components in the out-of-the-box catalog. I know this is suppose to be a starting point for the users, and we need to make changes, but it seems obvious that either; Autodesk didn't care to check the dimensions of certain components, outsourced it and a conversion from metric to imperial is off, or they used some non-standard manufacturer to come up with the numbers. I have found gasket thicknesses to be completely wrong. Reducer lengths to be out to .xxxxx decimal places that are so random. Make them a round/standard number. Those are just a few of many i have found.
5. Let us make changes to the spec in the spec editor while Plant3D is open!! (what a pain to constantly be switching)
6. Ortho creation is a joke (not sure how to complete a full multidiscipline project drawing set using models exported from different softwares)
7. Alternate ISOMETRIC naming schemes instead of just LineNumber-1...-2...etc.
8. Easier to manipulate ISOMETRIC settings
9. It would be nice if after placing a custom part using PLANTCUSTOMPARTS to be able to attach extra 3D modeled pieces to the new custom part. When you create a piece of equipment you can model up extra 3D detail and use PLANTEQUIPMENTATTACH to basically "union" it to the piece of equipment. If we could do the same for custom parts, that would eliminated having to create blocks.
10. Make it so Plant3D equipment looks nicer in navisworks. If i create a tank with domed roof, even when changing the faceting factor in navisworks to something very high, the tank still does not show a very smooth diameter or domed head.
11. Ductwork/process conveying line styles/equipment in P&ID. I know PIP standard doesnt cover that, but i would be great to have ductwork line styles/tags/equipment to be placed on P&ID.
almost forgot.. Vault integration if it makes sense. Would like to see how its implementation could benefit this software.
1. We have a plugin that does this: http://www.pdoteam.com/store/pdo-extended-fields/
4. Is a known issue and being worked on.
5. Whole heartedly agree.
7. You can - I need to write a blog post on it.
Addendum - Vault integration is available for subscription members as an extension. http://docs.autodesk.com/PLNT3D/2013/ENU/index.html?url=filesPSU/GUID-9FBEF151-97D3-40E5-A3CA-A4BD73...
eliszymanowski7369, about your point 7: check my post at Dave Tyner's site about this :
http://www.davetyner.com/forum/showthread.php?11206-Isometric-file-naming
The attributes that can be used are defined in the Iso.atr which is in the same folder as the isoconfig. They are defined by setting the mappings in the title block (or manually by editing the files).
Hello! Created account just to give my input to future releases of Plnat 3D so please take note and correct me if I'm wrong. I am a fan of Autodesk Products and we need a change in softare where I work.
1***. We need a complex Highlight/Select Filter for ALL of the elements in the workspace. Currently you can only set in the settings that the lines be created on teir own layer OR that the Items be on their own layer etc. However if you switch back and forth between theese they loose their information. This is stupid. We work with Pllant 4D (Add-in to AutoCad/AutoCad Mechanical) here and there is a most beatifull filter: it allows me to select multiple lines, multiple items/elements and to Highlight/Select/Isolate. Great thing this is! At a push of a button I can isolate/select/highlight 3 or x no of lines, all of the valves, all of the elbows, all of the pumps etc AND swith back and forth, add/subtract from the filter whatever elemts I want. This is a valuable asset for any plant designer: to switch lines off/on, select things obscurred by floors/other elemets and do this quicly. Right click + select line it's almost useless and hard on the system. The little light bulb on the layer drives me nuts.
Tell me: how can I isolate one line, move it/modify it/ then revert back to my workspace provided that I already had a few layers off (like the platform jackets, the steel structure)? And don't throw me the group, save layer state or something like that, those are not practical at allll. Really, do I have to think about layer state saves instead of the actual process at hand?
Btw, CEA Plant4D is data based driven software. Is this better or worse for cad?
2**. We need ASAP easyer support creator!!! It's a hassle to create a support. Where is the simple U-Bolt with one/double nuts? Why do I have a Height and Width of the nuts instead of the stanrd M16/M10 etc? Or at least put this as an OR option for putting standard or custom nuts on the pipe support. Also it would be great if we could drag their heght. Custom support is just as block with a fancy tag.
3. About custom equipment has already been said alot.
4*. We need a middle point for Elbows so that we can place the elbow at the intersection of two lines and continue from that point onwards.
5. We need more isometric customisation, let me choose the model and the colour of the flanges.
6. We need a more easyer class creator (it's not complicated but very frustrating).
7. We could use some 3d dimensioning, that is always level with the screen for easy reading and location of equipment.
That is all, I think. I really, really like Plant3D to the Plant 4D that we use. could this be implemented, do you, Autodesk, have time to implement all of our request or the project leader only chooses a few from the lot?
Thank you for reading my very first Autodesk post.
I would like to be able to use the PnPID in the ISO metric as the "Item Number", imagine if when reviewing the ISO, you can look at the PnPID and then make an edit in an excel spread sheet (that has been exported from the data manager).
And it would make matching up the ISO to a full BOM generated by the Report Generator easier.
2 other ideas I have come up with in the last few days that would be great time savers are as follows:
1. After using PLANTEQUIPMENTCONVERT to convert some 3Dsolids/surfaces to a Plant3D equipment I would like to add nozzles and have them behave like nozzles on equipment created using the templates in PLANTEQUIPMENTCREATE. So far when i try to add nozzles on converted shapes there is no "graphic" of the nozzle and it is only assume to exist even though I pick the size, rating, and type, it never appears. All that shows up is a "+" to start routing pipe from. It would be nice if it acted like nozzles on other pieces of equipment.
2. I dont understand why that when in the spec editor and after adding a new part to a spec, for example a weldolet, and i want to hide some of the sizes (with the weldolets there are over 100 at least) I cannot ****/ctrl click and select multiple sizes at once to click the check box to hide. Currently I have to click every single box (maybe i only want 1 or 2 out of the 100). Either a "Select all" checkbox or the abilitly to highlight multiple sizes at once and check the box to hide them would save much time.
I really would like to have the ISO a multi thread tool ie:
When it has created a PCF file, start generating another PCF file (as it currently does) but also start to generate the final DWG (and/or spread sheets) so we can start to work with the end data more quikly.
How about a sequential preffix and suffix added to the PDF to generate. This is for printing a multi-sheet document; the PDF's will then be called 2"-ACM3A-...-ET_SH1, 2"-ACM3A-...-ET_SH2, 2"-ACM3A-...-ET_SH3. A suffix/preffix for print/publish will be much appreciated (for all autocad products) and if possible a button to create sequential numbers, like in 3DsMax. So the know-how exists, it was implemented and tested, it just needs porting.
