AutoCAD Plant 3D General DIscussion
PatrickByrne
Message 71 of 200 (1,298 Views)
Re: Wish List AutoCAD Plant3D 2014
11-12-2012 12:42 AM in reply to: PatrickByrne
It would be good if the data manager in the drawing had all the information available from the database including Line numbers, file names plus when you have “Current Drawing Data” selected that it also gives you the option to select xref’s in that drawing. This way you could get a quick MTO without having to select the drawings in the Report Generator.
Valued Mentor
Rich.O.3d
Message 72 of 200 (1,290 Views)
11-12-2012 03:36 PM in reply to: ybogdanov
the ability to set the line gap/loop to break the horizontal in P&ID (as an option in properties with default being vertical)
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Valued Contributor
peter.jansoone
Message 73 of 200 (1,280 Views)
11-13-2012 02:52 AM in reply to: ybogdanov
P&ID + P3D: a command that copies from one item to another (fe when the tag edit dialog for a pomp is selected, it should be possible to copy properties from another pump in teh 'existing items' list ). The properties that must be copied can be flagged in the project setup.
Peter Jansoone
Plant Design software consultant at Greenock CAD service
Valued Contributor
peter.jansoone
Message 74 of 200 (1,275 Views)
11-13-2012 10:32 AM in reply to: ybogdanov
P&ID : aquisition for multiple sources : A 3 or 4 way valve is connected to multiple pipe segments and should show the different sizes. I'ts possible for reducers, shouldn't be too difficult
Peter Jansoone
Active Contributor
milan.blom
Message 75 of 200 (1,162 Views)
Selection criteria in report creator
11-26-2012 02:49 AM in reply to: ybogdanov
Selection of line number or other criteriu in Report creator.
Currently in report creator you can only use project data or drawing data as a data source.
I would like to be able to select one or more line numbers from one or more drawing files or some other criterium that makes sense (like area or service) from which i can create a report. Now it's all or nothing.
Reason: For example when issuing a series of isometrics i would like to create a bulk bill of materials for thos iso's.
Valued Mentor
ybogdanov
Message 76 of 200 (1,159 Views)
Re: Selection criteria in report creator
11-26-2012 03:11 AM in reply to: milan.blom
You can use filters in "Edit Query", column "Filter" (show filters examples in left down part of screen of window).
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Active Contributor
milan.blom
Message 77 of 200 (1,154 Views)
11-26-2012 05:24 AM in reply to: ybogdanov
I'm aware of that possibility, but editing the query for a report is not somthing I would have a regular user do.
Apart from the harm you can do editing the query, it's way to complicated. Moreover, using this function would mean manually typing in every line number you want to add to the query.
What i'm looking for is a third radio button apart form project data and drawing data where you can select the line numbers you want from a selection list (and possibly some other criteria).
The only viable option I have right now is exporting everything to excel/access and filter out what I need, but that is not why we have a report creator.
PatrickByrne
Message 78 of 200 (1,143 Views)
11-26-2012 12:46 PM in reply to: milan.blom
CadWorx had a really simple way of getting MTO's. With a few clicks you could export a Bill of Material into Excel, Access, text or html from objects in the current drawing including xref's. You could select by line number or select the models, there was no need to worry about the Database or Report generator.
It would be great if there was something similar in the next release of Plant 3D.
Valued Mentor
Rich.O.3d
Message 79 of 200 (1,137 Views)
11-26-2012 08:16 PM in reply to: ybogdanov
+1 for:
Cable Trays
ortho
P&ID
dont need structural improvement from within plant, but deffiinetly need MUCH better integration with ASD/Revit/Inventor
CAD Management 101:
VTU-REl
Message 80 of 200 (1,103 Views)
11-29-2012 01:05 AM in reply to: ybogdanov
A good "Gets startet" Tutorial as PDF file for Plant 3d in ENG and GER.
Who knows nothing has to do anything
Hard-working people aware of their surroundings fit.
Lazy people adapt their environment to itself.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
