AutoCAD Plant 3D General DIscussion
Active Member
daniel
Message 41 of 200 (1,597 Views)
Re: Wish List AutoCAD Plant3D 2014
09-24-2012 04:41 PM in reply to: ybogdanov
a match line number & spec button..
its slow to go to properties and change line numbers, when one exists already, plus its a pain when my line number list is in the hundreds.... scrolling through them all...ahhhhh!!!! help!
daniel
VTU-REl
Message 42 of 200 (1,534 Views)
10-04-2012 06:32 AM in reply to: ybogdanov
I miss an "Explorer" for Piplins to finde fast pipline parts.
Who knows nothing has to do anything
Hard-working people aware of their surroundings fit.
Lazy people adapt their environment to itself.
dave.wolfe
Message 43 of 200 (1,531 Views)
10-04-2012 07:15 AM in reply to: VTU-REl
Use the data manager. In 2013 you can use the drop down at the bottom left to switch the view to by area, and then you can view line groups.  Click on the header row will select and zoom to the items even if they are in another drawing.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
VTU-REl
Message 44 of 200 (1,526 Views)
10-04-2012 08:07 AM in reply to: dave.wolfe
Sorry I don´t know how.
in my Datamanger 2012 German version is that not available.
dave.wolfe
Message 45 of 200 (1,523 Views)
10-04-2012 08:22 AM in reply to: VTU-REl
For 2012, you have to go to  Project Setup > Plant 3D DWG Settings > Data Manager Configuration > Order by Area.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Member
DanG...
Message 46 of 200 (1,500 Views)
10-05-2012 09:00 AM in reply to: ybogdanov
I´d like to have a annotation preview in ortho-drawings
PatrickByrne
Message 47 of 200 (1,481 Views)
10-06-2012 01:43 AM in reply to: DanG...
Annotate xref assemblies similar to Orthographic Views.
We create our arrangement drawings by using xrefs of our steelwork and pipework models, these are very large and contain Prosteel objects. At this stage we will not be using Plant 3D orthographic views.
It would be good if Plant 3D could do this by retrieving the line number, or tag information from the xref model and placing it in Paperspace. Similar to how CadWorx does it.
PatrickByrne
Message 48 of 200 (1,480 Views)
10-06-2012 01:44 AM in reply to: PatrickByrne
Add expansion joints as a Plant 3D piping component, they are a common pipe line item. Presently I have to make a custom block for each size.
PatrickByrne
Message 49 of 200 (1,477 Views)
Re: e: Wish List AutoCAD Plant3D 2014
10-06-2012 01:45 AM in reply to: PatrickByrne
Isometric start point.
I have mentioned this in an earlier post and the response from Autodesk support is it will be logged as an enhancement request.
On our last project using CadWorx we had over 400 pipe models creating over 550 isometrics. I could open a piping assembly and batch create the isometrics, having the Isogenstartpoint set up on each model saved a lot of time and rework. This type of command should not be thought of as an enhancement but a necessary part of the program.
PatrickByrne
Message 50 of 200 (1,470 Views)
10-06-2012 03:37 AM in reply to: PatrickByrne
Speed up Isometric creation. While it does work in the background this is not much help since you usually have the model finished and are waiting for the isometric to see that everything is correct.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
