AutoCAD Plant 3D General DIscussion
Valued Contributor
Jorgen1990
Message 21 of 200 (2,135 Views)
Re: Wish List AutoCAD Plant3D 2014
06-14-2012 10:52 PM in reply to: dave.wolfe
What I meant was to be able to create orthos without getting the ortho dwg-s to Project Manager... because P3D often creates corrupted orthos (some lines missing, some valves cut half..) and I need to make multiple orthos to get a correct one and I don't want the Project Manager to be filled with trash orthos. Just like with ISO-s: you get to "test" the isos and dwg-s capability of creating isos correctly with quick iso command before creating the production isos.
Jörgen
New Member
manuel
Message 22 of 200 (2,125 Views)
06-20-2012 04:09 AM in reply to: ybogdanov
Integration with Vault would be a huge advantage, especially for projects with multiple users
Valued Mentor
ybogdanov
Message 23 of 200 (2,089 Views)
07-13-2012 11:59 AM in reply to: ybogdanov
Another important thing:
- Posibility to use catalog elements during CustomPart inserction.
- Posibility to use "Auxiliar SPECS" (like suports for example) which will be adapt to current spec.
The tarjet of this two solutionts is posibility to have one catalog of ALL Valves, and another catalog of ALL Instruments for example. And when I rute any pipe with spec CS300 for example and I want to insert any valve, it will be posible to insert valve from this "Auxiliar Spec" and this valve is necessary to adapt automatically to the current spec (CS300).
 I think that there are projects that you don't know which type of valves you go to using. And may be there are 30 types of valves. That's why the better solution is not to have this elements in each spec.
 One spec for valves and instruments, like suports spec.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
ie
Member
ie
Message 24 of 200 (2,077 Views)
07-16-2012 03:40 AM in reply to: ybogdanov
I didn't understand all of your story but imo that's the reason for the "placeholder" option when inserting Custom part...
Afterwards, when the decision has been made, you can replace the placeholder with the defined valve.
Below is wat I meant...
Best regards,
Valued Mentor
ybogdanov
Message 25 of 200 (2,057 Views)
07-20-2012 05:57 AM in reply to: ie
In custom Part menu is not posible to insert elements from catalogs directly, without using spec.
Yury Bogdanov
Barcelona (Spain)
Distinguished Contributor
jeromecastaneda
Message 26 of 200 (2,039 Views)
07-25-2012 09:50 PM in reply to: ybogdanov
What about creating Ducting, Transition bends, Ducting supports.
I hope this will be included.
http://engr.jeromecastaneda.com/
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.” - Albert Pine
Active Contributor
milan.blom
Message 27 of 200 (1,982 Views)
08-21-2012 01:21 AM in reply to: jeromecastaneda
Configurable automatic weld numbering
- Choose (part of) line to number
- Choose starting point
- Choose starting number
- Coose branches
For me as piping contractor consistent weld numbering through revisions is key, beacuse of welding tracability.
Welds on supports
Adding welds on supports like welded shoes and for things like shear lugs and weld eyes
Additional materials
Things like shear lugs that belong to the pipeline and you may want in the material list
Generation of 3D PDF
I am aware of the possibility to generate 3D DWFx and NWD files, but they require a viewer to be installed, which can be a problem for clients with regard to ICT restrictions.
DWFx can also work online with Autocad 360, but this requires registration for the client and the performance and functionality is limited (layers, viewpoints, animations, lighting, etc.)
Valued Contributor
chad70811
Message 28 of 200 (1,966 Views)
08-22-2012 09:12 AM in reply to: milan.blom
1)Please provide us with the ability to place reference points in a 3d model that will show up with dimensions on isometrics,  for example have it show reference dimensions from a column line to the center line of pipe?
2)Also please fix the insulation and grating display abilities in navisworks, currently they only show correctly in Navisworks if you export an .nwc from Plant3d 2013.
Employee
MaxDeardorff
Message 29 of 200 (1,950 Views)
08-22-2012 01:52 PM in reply to: ybogdanov
All,
This is great information - keep it coming.
Thank you,
-Max
Max Deardorff
Sr. Software Development Manager
ICP Plant Solutions
Valued Mentor
Rich.O.3d
Message 30 of 200 (1,870 Views)
09-06-2012 03:11 PM in reply to: chad70811
Seconded
it would be great if you could bring through a grid line to dimension to.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
