AutoCAD Plant 3D General DIscussion
Valued Mentor
ybogdanov
Message 11 of 200 (2,383 Views)
Re: Wish List AutoCAD Plant3D 2014
05-20-2012 01:37 PM in reply to: ybogdanov
- Create instruments in Spec Editor (the instrument Type is not avaibale for new components).
- Any aplication for control all symbols (blocks) in the project. For substitute the parametric simbols to custom simbols in the final part of project. For create better presentation in Navisworks.
- Automatic representation of insulation in isos of pipes.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
jeromefc
Message 12 of 200 (2,356 Views)
05-24-2012 06:14 AM in reply to: ybogdanov
Vault integration please.
Valued Mentor
ybogdanov
Message 13 of 200 (2,345 Views)
05-25-2012 02:20 PM in reply to: jeromefc
- using metric units in metric project when is defined dimensions for custom imerial parts. - change height of rows in iso table. When is insert some column for "class/pn" this column is convert in doble row because the name of property is too but is necesarry to do that the height of row is couldn't depen of name of property, because t'he most important is value.
Yury Bogdanov
Barcelona (Spain)
Valued Contributor
Jorgen1990
Message 14 of 200 (2,327 Views)
05-29-2012 06:22 AM in reply to: ybogdanov
I wish a better overall performance (less unexplainable errors). 2013 is already much better than 2012 was, but still some things are bad. For example, I regulary experience pipelines losing the data they have in Properties panel (Size, spec, material and so on) and their functionality (can't continue routing, can't insert components, can't lengthen). This is really annoying error. Sometimes a save and autocad restart helps, bus sometimes I just have to re-draw the whole pipeline. And I have run the "recover" on drawing.
I added an explanatory screenshot to make it clear what I mean.
Jörgen
Valued Mentor
ybogdanov
Message 15 of 200 (2,321 Views)
05-29-2012 06:33 AM in reply to: Jorgen1990
Jörgen
Don't use recover option in Plant3D because is posible to lose link with database (in same objects of the drawing).
Yury Bogdanov
Barcelona (Spain)
Valued Contributor
Jorgen1990
Message 16 of 200 (2,293 Views)
06-05-2012 04:12 AM in reply to: ybogdanov
Thanks for the advice! But the problem occured BEFORE I ran the "recover" on drawing, so this can't be the reason... and also, sometimes when I want to open a dwg in Plant 3D, the programs tells me there are errors in dwg and I have to recover before I can open the dwg.
sorry for the offtopic!
Jörgen
Valued Contributor
Jorgen1990
Message 17 of 200 (2,277 Views)
06-07-2012 07:37 AM in reply to: ybogdanov
Also a wish for Plant 3D 2014: "Quick ortho" command for testing ortho creation (so that program doesn't add the ortho dwg into the Project Manager, similiarily to Quick Iso).
Employee
PeterQuinn
Message 18 of 200 (2,271 Views)
06-07-2012 11:31 AM in reply to: Jorgen1990
Quick ortho. That's an interesting idea.
Peter Quinn
Senior Product Manager
dave.wolfe
Message 19 of 200 (2,269 Views)
06-07-2012 02:06 PM in reply to: PeterQuinn
I'm sure Jorgen meant to add that he wanted more features available for configuring orthos before a quick ortho was developed...right?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Valued Mentor
ybogdanov
Message 20 of 200 (2,258 Views)
06-07-2012 11:55 PM in reply to: dave.wolfe
The ortho now is the alhilles heel of Plant3D. There are many futures wich is posible to copy from AutoCAD MEP. Because it's just what need our customers.
Yury Bogdanov
Barcelona (Spain)
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
