Let's go to remember the old wish list for developer team of Plant3D, and will add new points. Please, update the list with copy past and future comments:
1. Dinamic Symbol ToolPalett for P&ID (Spec Driven P&ID)
2. Cable tray in 3D
3. Rectangular pipes - ducts.
4. Civil inteligent modeling
5. Integration of AutoCAD Structural Detailing tools in Plant3D or recognize steel members of ASD.
6. Modify Steel member catalog
7. Insert components in 3D directly from catalog (as Custom Part option)
8. 3D elements sets - for example: Socketweld+Nipple PE+SW Valve + Nipple TOE + Plug, all this with one click.
9. Reference representations in isos, for example wall or steel member
10. In ortho posibility to hide layers and objects during configuration of orthoview. Posibility to generate isometric-ortho view of one selected line number.
11. Automatic Ortho dimensions
12. In ortho cut solid simbols, for example walls or equipments.
13. Automatic Ortho annotations
14. Tubing routing without bends and elbows (with curve pipes)
15. Jacketed pipes
16. Time of ISO generation in By-pass lines
17. Include in Project Setup: Title Block Link - for all: P&ID. ISOS, Orthos. This link it will be update all existing layouts and sync Title Blocks
18. Mark in P&ID Line List inserted objects in 3D, now it's imposible to view if the valve was inserted or no
19. Function for 3D objects "licalizate in P&ID", and for P&ID objects "localizate in 3D" (the same function like "surf" in AutoCAD Electrical)
20. Create instrument elements in Spec Editor
We use Plant 3D where I am working, and as the person that has to build the Electrical Racking into the 3D model. I find it unbelivable that Autodesk has not put a facility for the building of Cable Racking into Plant 3D, as this is a very inportant part of a Plant model. We are expected to payout for a further very expensive program, after already paying for the expensive Plant 3D, just to use one small section of the other program. I have never had this problem when I was using PDMS. So my main wish for Plant 3D is a usable way of modling racking as standard in Plant 3D.
One of the problems is that cable tray and associated design isn't similar to piping components. Its the same problem with getting a piping design program to do structural design.
The objects in the program are designed with specific properties and methods based on what they are and how they behave in the model. Most piping objects behave in a very similar fashion, such that they can be defined as a base object with intermediate objects which add more properties and methods, with those extended to more specific objects, and so on. Cable tray and structural objects don't share a lot in common with piping, so a whole new development stream has to be added for each of them. That includes not only programming but also subject matter experts and creating some basic data sets.
Not saying that its impossible, but could be more difficult than it initially appears. I know - I've built a cable tray design system.
Are we still talking about Plant 3D? because it DOES provide with some structural features - including stairs ,railings, plates etc. the program is called PLANT 3D for reason. if they say they cannot provide stuff like thi - so they have to stop selling it as plant software and continue as piping software.
Which is my point. Nobody would confuse the structural capabilities in Plant3D with Revit Structural, Tekla, or any of the other structural design programs. By the same token, we shouldn't expect detailed cable tray design as found in programs dedicated to that function. At best we would see a rough equivalent to the structural capabilities - something to rough it in. If something more detailed is desired then the appropriate software can be used, or a custom solution can be bought or created.
I'm recreating the idea list here:
This will allow users to vote on ideas so that the best ones get floated to the top. It only works if everyone gets involved, so feel free to participate!
Item 28 is a duplicate of item 10, I believe. Item 34 is complete. In naviworks the insulation is on the P3dInsulationLayer. That just isn't exposed in AutoCAD, so you don't see it unless you know it's there. I think 42 is a duplicate of 23 essentially, and I think 44 is a duplicate of 2 and 3.
Ideally everyone will jump on board with this list. It should be far easier to track and rank, and we won't have to update the list for each release.
Thanks Dave.
just my opinion of needs rather than wish...
All of these items were captured here: and we have even had several people voting on their favorites. Feel free to contribute:
-More command of layering and Linetypes in Ortho generation.
examples:
Better layer On/Off capabilities.
If pipe is on a 'hidden' (dashed) line type when ortho'd it shows as a hidden line. Or have another property that states above or below grade. Below grade then = hidden line type on Ortho. (I have made numerous posts/ threads on below grade pipe. #1 GOOGE search result. There are only work arounds, we need dedicated control for how to show Below Grade Pipe.)
Existing Pipe - if status is set to existing, the centerline on Orthos should be independent of Proposed pipe. As of now they share the same layer even if you have separate Existing and Proposed piping files.
Also,
Weld by Flange Valves in catalog. They are standardized valves, they should be included. I shouldn't have to make them.
https://plant3d.uservoice.com/forums/263656-plant-3d-wishlist/filters/top
This isn't a poll per se. I'm planning on leaving it open. I'll do my best to make sure features get marked as completed as Autodesk addresses them. So, this should be a permanent wishlist that reflects the current state of Plant 3d.
@JoeKay Please add a request for underground piping in the uservoice wishlist. It'd be nice to see some votes for that.
-First off, make the Match type property as powerful as the Eye droper in ArchiCAD, i loved that in ArchiCAD.
-In Floor Plan view, eassy and fast toggle on/off see through any other floors or multible floors, can change capacity!! better with shortcut key for it.
face it, everyone hates menu. so less menu as much as possible.
I would like to see the ability to insert equipment from the P&ID list. This will complete the insert from P&ID.
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
Have a look at the Plant3D IdeaStation: http://forums.autodesk.com/t5/autocad-plant-3d-p-id/idb-p/48
This is a curated list so the developers will have a better idea of what ideas are more popular.
