AutoCAD Plant 3D Forum
WISH LIST AUTOCAD PLANT 3D 2015
91 REPLIES 91
Message 1 of 92
Arun_Kumar_K
8315 Views, 91 Replies
I would like to start to give work for the developers even before the official release. As I understood from the 2014, these are not available; please take the following in 2015 release:
1. Spec driven P&ID.
2. Per bid engineering ( for proposal purpose). The prices will be fed for all particular items in spec, in report creator, the costing should appear after multiplication with the quantity
3. Direct stress analysis link with any major softwares like CAESAR, CAEPIPE or Rohr2.
4. Basic civil shape intelligent for columns, footings, beams, windows, doors and staircase
5. Basic electrical intelligence for electrical cable trays, ducts etc.,
6. Custom parametric modelling of supports and equipment a as per user wish.
7. Display of coordinates for pipes in Navisworks.
8. Built-up section structural steel member creation and display of centr line of structural steel members in ortho view.
9. IS standard incorporation in steel catalog.
10. Steel structure report in Report creator
91 REPLIES 91
Message 41 of 92
Arun_Kumar_K
in reply to: bmv1365
Yes, It would be nice to have a feature shown in M.JPG for representation of Insulation symbol.
Message 42 of 92
Arun_Kumar_K
Valid and more Important points mentioned. Thanks for brought to the notice of Autodesk.
Message 43 of 92
tarheels09
in reply to: Arun_Kumar_K
It would be nice to be able to xref Plant3d files to revit, or even better attach revit files to Plant3d. Just think of the possibilities. Now that would be an improvement.
Message 44 of 92
dennis
P3D: Create Equipment
1) After selecting shapes, give me a button to show the assembled shapes
2) Part SubType Setting, currently can only change that after insertion
3) Access to the P&ID Equipment Tag data
Currently, if you place a tank, its Part subtype =  General Vessel, change that to Dome after placeing, then edit a nozzle, it will revert back to General Vessel.  I woul like that fixed.
Project manager: let me right-click and xref a dwg into the current dwg.
Message 45 of 92
MSpadaro
generate 1 isometric dwg from 2 or more Piping lines using PRODUCTIONISO and not QUICK ISO.
Message 46 of 92
eski
It seems like Plant3D 2014 did address some issues we were having with the 2013 release, but not all things have been fixed (as expected).  I see the following improvements as a necessity for Plant3D make:
1] Revise/check the dimensions of components in the out-of-the-box catalog.  I know this is supposed to be a starting point for the users, and we need to make changes, but it seems obvious that either; Autodesk didn't care to check the dimensions of certain components, outsourced it and a conversion from metric to imperial is off, or they used some non-standard manufacturer to come up with the numbers.  I have found gasket thicknesses to be completely wrong.  Reducer lengths to be out to .xxxxx decimal places that are so random.  Make them a round/standard number.  Those are just a few of many I have found.  I cannot believe this has yet to be acknowledged and fixed!! Completely ridiculous and irresponsible in my opinion.  Doing a fitting-to-fitting stack up of these odd dimensioned components results in an incorrect overall length over time.
2] I also can't believe that the ORTHO creation has been fixed to allow for freezing of layers.  I will admit they made some decent improvements to the ORTHOs for the 2014 release.  But we need to be able to turn off certain layers or override the layer properties in the "green box view" and have those changes saved and shown on the resulting ORTHO view.  I have explained this in much more detail to Autodesk in cases, and over the phone and they have admitted that this should work and they would like to fix it. SO FIX IT!!! We cannot utilize the ORTHO creation tools at this time until something like this works.  I would really like to talk to someone at Autodesk about this more and show them firsthand how it should behave.
3] When a pipe is selected, it would be nice to have the T.O.P./C.O.P./B.O.P (maybe even T.O.I./B.O.I) listed in the properties palette for easy entry/changing.  Currently clicking the little arrow when the pipe is selected and "tabbing" to either T.O.P./C.O.P./B.O.P works, but sometimes they are out of the current zoom level view or are stacked on top of each other.  I realize there is an expanded field’s add-on that can do this.  But this should be built in.
4] Showing insulation as a separate component in Plant3D and Navisworks that could possibly be selected and given a transparency.  We like to see the actual pipe and then a transparent insulation around the pipe in the model. The current method of just expanding the pipes OD does not cut it.  Currently I trace my pipe lines with a 3Dpolyline then sweep a circle with a diameter of the insulation and put on a separate insulation layer.  This is a workaround but if I change my pipe, editing the swept solid is a bit of a pain.
5] Easier ability to set up a naming convention for ISOs in the project setup. [Like the fine name format in general settings]
6] Easier configuration of ISO settings.  More settings have been added to the "Isometric DWG Settings" in project setup and you can manipulate a lot thru the "setup titleblock" environment and the isoconfig.xml.  But seems counter-intuitive to have multiple places to make changes on how the ISOs look and act.  Consolidate the settings to fewer places so it's easier to manage.  Maybe start by adding all the options throughout the isoconfig.xml to somewhere in the ACAD UI.  I think manipulating the isoconfig.xml scares off new users.
7] Need to choose ISO start point and flow direction.  Leaving that up to the software's Isometric engine does not always create best results.
8] Add the ability to reference objects in ISOs [ex. dimensions to columns]
9] Even with the default theme set to put "tables" on the "Table" layer, when I run some ISOs the table is on layer "0"
10] The continuation symbol on ISOs [block name Split Mark] needs to have linetype set as ByBlock so on the ISOs the linetype shows as "Dashed".  Currently set to "Continuous" in block editor, so on ISOs the continuation symbol doesn’t show "Dashed".  And with further investigation, I go into the block editor for that symbol on an ISO and it seems that the "squiggle" /break polyline of the symbol is on layer "table" [very odd]
11] Cannot get the dimension style to control how trailing zeros are displayed in ISOs.  I want a dimension of 4 feet even to display as 4'-0".  Currently it only shows as 4'.
12] While inserting a component from the tool palette or even the spec viewer, more insertion points should be created for quicker insertion at intersections.  For instance, why can you not cycle to the workpoint on an elbow as an insertion point rather than just the two ends?  If you have "Nearest" snap on and you move the component to be on a pipe you can sometimes get to the work point by using the "Basepoint" settings.  So why not just have the ability to hit Next to get to the work point of components?
13] Possibly more equipment templates. There are some there, but a bit more detail with pumps would be nice. [ex. diaphragm pump template]
14] I don’t understand why that when in the spec editor and after adding a new part to a spec, for example a weldolet, and I want to hide some of the sizes (with the weldolets there are over 100 at least) I cannot hold shift on one size then click another one further down the list then click the check box to hide.  Currently I have to click every single box (maybe I only want 1 or 2 out of the 100).  Either a "Select all" checkbox or the ability to highlight multiple sizes at once and check the box to hide them would save much time.
15] Update the images in the catalog editor "sizes" tab for components.  Sometimes those 3D views are hard to see and figure out exactly what the dimensions are dimensioning.  either be able to enlarge the image [like the custom part palette inside plant3d] or get rid of the 3D views and just have a more straight forward "front", "Top", "Side" view representation of the component and the dimensions should be easier to figure out.  [I realize you can hover over the parameter name to get a brief description, but the images should be better]
16] The ability to Drag & Drop files from the Plant 3D Drawings section on the Project Manager palette into open models that are part of the project for xref'ing.  This ability is part of ACAD Arch and MEP using the Project Navigator, and would be a real nice improvement.
17] Make it so Plant3D equipment looks nicer in Navisworks.  If I create a tank with domed roof, even when changing the faceting factor in Navisworks to something very high, the tank still does not show a very smooth diameter or domed head.
18] In 2014 the new point cloud engine is much nicer than the old and ReCap seems to be a decent software for a first release.  With some tweaks it could alleviate a lot of headaches while working with point clouds.  But one killer feature for Plant3D would be to have built in tools for tracing over the point cloud.  For example, tracing pipe using the Plant3D specs & the structural details with the built in structural catalog would be amazing. Also the ability to model in simple walls, floors, etc. would be great and prevent us from having to use 3rd party add-ons that just don’t seem to work that well most of the time.  I know you can do it Autodesk! I recently found the Feature extraction app that begins to trace with simple primitives, but utilizing Plant3D's specs would be much faster and nicer.
19] Add process conveying/duct work lines, symbols, tags, equipment, etc. for P&ID routing.  Process pipes are not the only thing in plants, and having to create custom entities to route ductwork on the P&IDs is time consuming.
Message 47 of 92
dgorsman
in reply to: eski
Could you give specific examples for point 1?  If you've check the ASME standards you will see the tolerances are *very* generous e.g. ASME B16.5 sec. 7.6 (weld neck flange length through hub) is +3.0/-5.0 millimeters from the given values for the indicated size range.  As long as the OOTB values are within this range they are acceptable.
Message 48 of 92
tarheels09
Point #18,  "the ability to model in simple floors" ,  We had to switch to Revit MEP because you cannot link a revit file to Plant3d. Working on a multi story water treatment plant was impossible. Even if you export the model to autocad there was no way to cut the model. Until this problem is addressed this program is not helpful on projects with buildings and not steel platforms.
Message 49 of 92
eski
in reply to: dgorsman
dgorsman,
Thanks for the reply.  I do understand that there are generous tolerances allowed through ASME.  But what I don't understand is why some of the components have dimensional parameters that are within the tolerance but do not match the nominal "standard" numbers.  One good example I found are the REDUCER (CONC) BW components.  If you go to the catalog and click many of the sizes, for this example lets say the 6"x4" size, and look at the "L" parameter.  Why does this equal 5.5118"?  Yes this falls within the allowable tolerance given in ASME B16.9 (see attached image #1) for overall length of reducers (+/- 1/16").  But why go to the trouble to type in 5.5118"?  Why not just use the nominal length that is referenced on most all charts and tables i could find, including the ASME B16.9 "dimensions of reducers" chart.  This clearly states a nominal length from end-to-end at 5.50" (see attached image #2).  This seems like a no brainer to me.  While this is a very small difference in length, over time, on a fitting-to-fitting stack up, these could throw the overall stack-up dimensions off.  I guess I just don't see the point in Plant3D having non-nominal dimensional parameters.  In AutoCad we would like to model up piping per a standard, and use "round" nominal sizes as much as possible. There are other examples I could provide, but honestly I have brought this issue up many times to Autodesk (one time they were on the phone looking at my screen, and acknowledged they were incorrrect themselves!).  Release after release, I have been hoping they would go back and change these "random" numbers to something more standard, and it never happens.  I really just want to know where they got this information?  Where did they come up with 5.5118"?  That is why I thought they either outsourced this data entry and it was a result of someone not knowing any better, a conversion error, or someone bought a reducer from a manufacturer and measured it up and put that number in.  Either way it was done, that is fine by me, but I just want to know why?  It'd be nice to have these all fixed instead of the users having to go in and edit dimensional data.  Sorry for the long response.  I hope you can understand our frustration.  Thanks
Message 50 of 92
dgorsman
in reply to: eski
No problems.  They may have used a conversion factor that was more or less decimal places than normal (25 instead of 25.4), or they may have taken a metric table that was converted to inches and back again (140 mm converts to 5.518 inches).  My main point is that if its within tolerance, then wanting another value (round or not) becomes one of personal preference which can easily be different between different users.  There's also another problem if they start changing part dimensions, even to just round them off, then there can be some blowback from the users as parts are suddenly not the same as before.
As for the cumulative error, thats handled in the design process.  Usually an overall dimension is specified and one of the part dimensions (normally pipe) is allowed to float; or specific coordinates are provided at critical connection points.  The construction folks out at the field have to deal with even larger tolerances out in the field, since they can get some thermal growth from just sitting out in the sun for a day or from welding.  By limiting the dimensions, we can let them construct it so it fits, regardless of issues like cumulative errors.  One of the leads I've work with at several companies has a saying: measure with a micrometer, mark with a pencil, cut with a chainsaw, backfill with weld.
In certain cases it becomes very critical to get the right spacing (like large headers on air coolers).  We've taken to using pulled tee headers where this spacing gets critical, with good success.
Message 51 of 92
eski
dgorsman,
Thanks again for the response.  Yeah, thats what I was saying and thinking. They must have used some conversion factor that gave them the non-standard numbers (5.5118).  That could be the reason, we may never know haha.  I just know that if I was in charge of checking those numbers after they got converted and before sending them out to customers, personally I would have had a problem with that.  Maybe I am a bit too much of a perfectionist, but I like to design to the nominal numbers that I reference on charts.  I understand users may get upset if some of these components were suddenly changed in the next release, that is fine.  I have decided that they most likely will never get updated so I will just go ahead and change them myself and make them match the ASME B16.9 nominal dimensions.  When designing in CAD I would much rather use parts based off a nominal size and not ones that have been converted back and forth and are out to the .xxxxx decimal place.
I totally agree on your second paragraph though.  In the field, most likely these components will not be perfectly dimensioned out to 5.5" and we need to design for that by limiting the dimensions and let them construct it to fit.  That being said, I would still much rather design in CAD to nominal sized components.
Thanks again for the responses though. I really appreciate it.  Makes me feel like I am not alone out here in Plant3D world haha.
Message 52 of 92
PPlenevaux
in reply to: PatrickByrne
"Standardise the Plant 3D Catalog format so that they work with all releases or make available a convertor for saving to earlier releases. Presently you have different content packs available for different releases but the newer ones cannot be used by earlier releases. It is also a bit of a pain Migrating specs and catalogs for each version."
I really do agree with this. It's really bothering to migrate at each new release. Migration is easy for native components in specs and catalogs, but it's not the same for user defined ones...
Pascal
PRAYON sa
Message 53 of 92
Rasenberger
One of my wishes is  a way  to refer to the isometric piping on the steel structure or building axes.
Message 54 of 92
ARB_Drafter
This may have been stated already, but how about a Force Onto One Iso button that actually does something.  I have a pipe that is coming off a vertical riser runs at +29.94° East into another vertical riser.  Both elbows are 90°.  Should be a simple rolled elbow, but Plant 2013 can't manage to put it on one Iso.
Message 55 of 92
ybogdanov
- Assign P&ID OPC number by its position in drawing. Creating P&ID drawing quadrants, for example: A-1, A-2... Where "A" - is horizontal divisions, and 1, 2 is vertical.
 - In calculation bolt lenght add the thickness of fasteners, as Stub End thickness. There are cases when the Lap Flanges are join with valves, where thickness of valve's flange is smaller than thickness of stub-end. In this case, bolts will be smaller. Now it's not work. It's case of plastic stub-ends where the thickness is big.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 56 of 92
RKelly56
Can Autodesk add ASME flanged and dished heads, Standard flanged and dished heads, 2:1 Elliptical flanged and dished heads and 80% dish and 10% knuckle radius heads to the list for creating equipment. Is there an add on for those type of heads anywhere?
Message 57 of 92
dave.wolfe
in reply to: RKelly56
Autodesk would have to add it. 3rd party people can't modify the list of available shapes, as they are hardcoded into the scripting routines.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 58 of 92
patpat78
my wish list for acad 2015 do not make a 2015 rlz....
we use plant 3d since 2011 version so in our computeur we must have 2011 2012 2013 2014 version in.. why ? just because convert project doesn't work there is always bug ... and we don't want this
so any years we need to config again all plant 3d and PID with our settings.... migarte spec or recreat spec because the migration fail...  .... why ?
why does autodesk doesn't work like pdms or other software when we see the difference between version a service pack can do this very quickly and without making project again and again and without having 4 versions of plant in the computer...
at this point in my office we are actually thinking about not upgrading plant because it's spe,nd to much time evry years... for only a little changement...
my opinion..
thank's
Message 59 of 92
kudryavcevrm
in reply to: patpat78
Message 60 of 92
cadwomen
in reply to: eski
if you take a deeper look in Vault your well realized the your wish is a bad ideea
its made by the defil
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
”Boost
