Hi, I'm June
i'm usuing 2013 version.
I was connected pipe & half coupling.(image attached No.1)
But If i make a iso drawing, it devided 2 drawings. (image attached No.2)
(I checked the Force one sheet option)
Why devided 2 drawings.. Please give me advise..
correct. I would also check in your spec that the branch table is populated properly, otherwise any branches won't connect and you will get the drip symbol at each connection.
i have the same BIG problem, but it is all connected and there is not drops.
In effect all the boxes in the branch table with half coupling are red, but I need that it is so!
What 'is the problem then?
Thank you.
Hi all,
Divided by tow because the half coupling not placed correctly on the pipe
You can check that by active the drop water on plant 3D
For more clarification refer to Screen shot
Ahmed Helal
The problem is from P3D.there is a problem with half coupling in P3D 2013,like what ahmed said u should use sockolet instead of half coupling and name it as "half coupling",unfortunately u have to add each size (header and riser) to your spec. and I didn't test half coupling in 2014.
Hi ,
The problem with half coupling spliiting in different isometric still occurs in Plant 3d 2015. Currently im using it in Plant 3d 2015.
However, when i change the skey type of the half coupling to MISC-COMPONENT, then i can generate it in one isometric.
I hope this information is helpful.
Br,
Sharon
HIO Arun_Kumar_K,
How to move the half coupling let it under olet component?
