AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
why devided 2 iso drawings? pipe & half coupling
11 REPLIES 11
Message 1 of 12
1286 Views, 11 Replies
Hi, I'm June
i'm usuing 2013 version.
I was connected pipe & half coupling.(image attached No.1)
But If i make a iso drawing, it devided 2 drawings. (image attached No.2)
(I checked the Force one sheet option)
Why devided 2 drawings.. Please give me advise..
11 REPLIES 11
Message 2 of 12
Arun_Kumar_K
Coupling not connected, that is the reason. right click on the main pipe and select connected line number, you will observe coupling without highlighting.
Message 3 of 12
correct. I would also check in your spec that the branch table is populated properly, otherwise any branches won't connect and you will get the drip symbol at each connection.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Message 4 of 12
i have the same BIG problem, but it is all connected and there is not drops.
In effect all the boxes in the branch table with half coupling are red, but I need that it is so!
What 'is the problem then?
Thank you.
Message 5 of 12
bmv1365
Are the Line no.s same in two created drawings?
Message 6 of 12
Yes, lines have the same line number.
Message 7 of 12
Half coupling will not be accepted in Branch table, the issue is there in the branch table, not in your plant3d.
Message 8 of 12
Ahmed1081975
in reply to: Arun_Kumar_K
Hi all,
Divided by tow because the half coupling not placed correctly on the pipe
You can check that by active the drop water on plant 3D
For more clarification refer to Screen shot
Ahmed Helal
Message 9 of 12
Arun_Kumar_K
in reply to: Ahmed1081975
In spec editor, the things fall under TEE and Olet only will be connected with pipe. Half coupling is falling under coupling section. If you still would like to use half coupling for branch, create a new component under Olet, name as Half coupling and define the properties after selecting a suitable block. This is a only solution I feel.
Message 10 of 12
bmv1365
The problem is from P3D.there is a problem with half coupling in P3D 2013,like what ahmed said u should use sockolet instead of half coupling and name it as "half coupling",unfortunately u have to add each size (header and riser) to your spec. and I didn't test half coupling in 2014.
Message 11 of 12
sharonleong8985
Hi ,
The problem with half coupling spliiting in different isometric still occurs in Plant 3d 2015. Currently im using it in Plant 3d 2015.
However, when i change the skey type of the half coupling to MISC-COMPONENT, then i can generate it in one isometric.
I hope this information is helpful.
Br,
Sharon
Message 12 of 12
rflin-CTCIM
in reply to: bmv1365
HIO  Arun_Kumar_K,
How to move the half coupling let it under olet component?
”Boost
