WARNING - Dimension (Id = 794) of Flange (Id = 51) seems to be disconnected from the rest of the model!
WARNING - EndConnection (Id = 593) of Connector (Id = 592) seems to be disconnected from the rest of the model!
Has anyone ever even asked a question how to use these Id = numbers to identify components in questions? Where are these numbers coming from? How did someone who wrote the code putting them out to a log, expected them to be used?
I would love to know the answer to this. I was hoping the number in parantheses would correspond to an item number in data manager but I have not found a correlation.
I've been unable to find a correlation.
These are ids are internal ids that help the developers debug problems. There's no correlation to the model. These are warnings can usually be ignored except if there is some problem showing up on the iso.
I'm having this warnings and the software is geneating one isometric per element. In the model, all elements are connected. I try force isometric in one sheet, change the level of congestion and even change some parameters in isoconfig.xml, as the maxdirectionchanges = 0, etc.
Nothing helped me to solve this issue. I need help please.
