AutoCAD Plant 3D General DIscussion
Valued Contributor
4 Kudos
Post 1 of 3
Weld neck flanges showing up as Socket weld flanges
234 Views, 2 Replies
10-03-2011 11:59 AM
I modified the ASME catalogue to display the items as SS items instead of CS. I kept all the properties the same, yet for some reason the Flange is showing up as a different type of flange.
Also possible related ssometimes  it picks and chooses when to display the fittings in the ISO drawings.
I am still using 2011 as well.
Valued Contributor
4 Kudos
Post 2 of 3
Re: Weld neck flanges showing up as Socket weld flanges
10-03-2011 06:32 PM in reply to: JRPalmer
Hello, can you try to look on your catalog editor the flange that you made its Iso Symbol SKEY. See if its FLWN
Valued Contributor
4 Kudos
Post 3 of 3
10-04-2011 07:15 AM in reply to: JRPalmer
Thanks I looked at the ISOkey on SPEC editor it had the correct value, but apperently I accidently changed it from FLWN to FLRFWN in the excel sheet which I used to automatically update Spec Editor..
Problem fixed
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
