Which utility has "Weld dots" ?
In the help :
"Weld dots
Diameter
Sets the size of weld dots and other connector objects (for example: a bolt set, or a threaded joint marker). In the model, welded joints are connector objects that display as a solid circle.
Solved by lopezjo. Go to Solution.
Try REGEN3 or closing and re-opening the DWG.
Also be sure to check the value of PLANTWELDDISPLAY.
using the command PLANTWELDDISPLAY and set "ON" this is the view:
Thank you very much!
