AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Warning box when migrating specs to 2014??
6 REPLIES 6
EricNyh
864 Views, 6 Replies
I've gone through the tools to migrate my catalogs and specs.  The process completed and said everything was fine.
For some reason, when I open the migrated spec, I get the following dialog box.  What's going on??
6 REPLIES 6
in reply to: EricNyh
I am having the same issue. I have tried serveral work arounds, but cannot get the catalog migrated.
I would hope that the programmers at Autodesk would respond to these problems quickly so that we can get our projects out the door.We have invested thousands of dollars in software and time to learn these programs and are at the mercy of Autodesk to get these problems fixed. So please Autodesk RESPOND so we can move on.
Attila.Vallyon
Yes,
I got the same problem. But I solved it.
I opened the spec file, than I closed that warning message than I save as... the spec file.
The new spec file worked well than.
Attila Vallyon
EricNyh
I tried the above solution, but for some reason I am unable to do a 'save as' with the same name.  I'll try again tomorrow by saving with a new name.
Attila.Vallyon
You have to change the name. Than you can delete the original spec, and than do an another save as to restore the original filename.
Attila Vallyon
EricNyh
That did the trick.  Thanks.
I'm sure that the Plant developers didn't intend the spec migration to work like this!!
TomislavGolubovic
Not being on the development team, I can't comment, but you wouldn't want a conversion to overwrite the original file, if something goes wrong, you can always try it again on the file that works, and its a form of backup to have the old version in one spot, and the converted in another.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
