AutoCAD Plant 3D Forum
Visual Style Manager
2 REPLIES 2
littlc
542 Views, 2 Replies
Does anyone have any insight on creating a visual style that will enable an isometric view viewport in paperspace to actually print hidden when selecting hidden from the shade plot properties. Solid faces either disappear or have diagonal lines crossing the face. Custom plant parts also disappear. Threaded ball valves and all check valves from a custom spec disappear. Pipe line weights become excessively thick. The list could go on and on. Other shade plot properties do not work when you want crisp black and white 3D drawings. Any help would be great. Is there a detailed reference about the Visual Style Manager options?
CL
2 REPLIES 2
FadeRat
in reply to: littlc
I am trying to figure this out myself. Have you had any luck?
The first picture I've attached is the clean lines I want, but without the diagnal lines on the jar filter.
The second picture is what it looks like when I set the shade plot to hidden.
Any help would be greatly appreciated.
Thank you.
littlc
in reply to: littlc
If you are just looking at a plan or section view I would use the "Create Ortho View" command, the more I use this, the more I like it. I have yet to get the diagonal lines to disappear on equipment when clipping a viewport in paperspace, whether it is an iso, plan or section.  I have a couple custom shade plot settings, but they still are not exactly what I want.
CL
”Boost
