AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Viewcube
5 REPLIES 5
754 Views, 5 Replies
Viewcube
Hi all,
I was just wondering if anyone has encountered any problems with there viewcube while modelling.  Mine seems to lock up on me on occasions and the only fix is to close the drawing and then re-open it.
5 REPLIES 5
Yes you are right. I reported this during 2011 Beta version a few months ago, still not fixed.
best
I have had some random, inconsistant luck by changing the view style. Otherwise, yes, I have to close and re-open the drawing.
I do have exactly the same problem.
CeconCraig
I have the same issue with 2015. Is there a fix?
patpat79
in reply to: CeconCraig
This case must be brought up to the product support of autodesk, though i havent notice this problem because since i have started 3dmodelling in autocad, i had used using the "alt+v+3+ (s,e,t, ect.)" method to change views.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
”Boost
