AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
View goes to extents after placing pipe component
4 REPLIES 4
aredling
430 Views, 4 Replies
After I place a pipe componenet (ball valve, needle valve, etc...) the model views way out to show 100% of the extents as I specify the angle/orientation of the component.
Anyone ever seen this?  How do I reset this setting?
thanks,
4 REPLIES 4
Asimo5000
in reply to: aredling
Is this right after you place the component, and then click on the view cube?
pendean
What is UCSFOLLOW variable set to?
aredling
in reply to: pendean
This occurs as the angle to place the component is being set.  So as soon as I click the component location in the model it zooms all the way out to the model extents, then I have to set the angle (which makes it almost impossible to do).
This must be a setting because none of the other models I have do this.
UCSFOLLOW: 1
thanks,
Adam
aredling
I checked the other models and UCSFOLLOW was 0.
Sure enough this problem was fixed when I updated from 1 to 0.
Thanks A MILLION!
-Adam
”Boost
