AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
vertically curved pipes?
1 REPLY 1
KenFoyster
244 Views, 1 Reply
I am using Plant 3D on a Wastewater Treatment Plant design project. The project consists of both above and below ground piping.
The above ground is basically flat and standard in format, but the below ground requires significant customisation and configuration.
A portion of the underground required the use of PE pipe to connect between DICL intel and outlets.
PE is flexible and can be layed  horizontally and vertically with Radi of 33xOD.
I reqiuire some assistant to how I represent that in my 3D model and ortho documentation.
Regards  Ken Foyster
1 REPLY 1
Ken, you can change the elbows to be bends, which in turn let you nominate the bend radius of them. Its in the ribbon next to the Spec Selector, the ability to have bends or not in the model.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
