How do I get the olets and associated piping/valves to register as drain/vent piping?
While most nipples and valves are showing up correctly, I can't get the o-let to consistently be small bore piping. This results in a bunch of olets showing up on the isometrics at full size but the connected nipple and valve to be at small bore scale.
Solved by jabowabo. Go to Solution.
Maybe this approach would meet your needs: Build vent/drain assembly?
I am muddling my way through the XML but my understanding is very rudimentary. Is there a way to add to the XML a filter that looks at Status field and then add a Drain/Vent to the status pull down list?
