Does anyone ever use Vault for managing Plant 3D datas? How is it?
I want to learn Vault. But it requires a server and client to finish the job. And I want to do in on my own computer at home.
Is it possible to set up a vitual server and install the software? How?
Solved by JarrodMudford. Go to Solution.
you can run vault on the same machine as plant 3d
DarrenP
how many users are planning to use vault?
DarrenP
just one for testing at the begining. If the test result is ok, we'll install them for totally 4 clients (users).
i suggest installing it on the machine with Plant 3D to get familar with how vault works
DarrenP
How would you suggest we manage a multi office project with 20 or more users. Half using PID and half modeling in Plant 3d. We will also be using revit Arc and Str on the project
I think taht the best way is work with Vault Professional. You need to download AutoCAD Plant3D Extension for Vault. Desinstall the Plant3D and install the extension. The problem is you couldn't to install any service pack and hot fix after that, because for extension is Plant3D but "special" work with Vault, but SP1 and hotfixes don't recognize it as Plant3D normal.
I think that in the next release it will be better integration...
Hi Mark,
On your PC, you can install the Server part of the Vault, and also the client. The server will just be known as localhost.
The compatibility between Plant3D and Vault is only on the Workgroup, Collaboration and Professional levels of Vault. The basic version of Vault is not supported. Therefore, you will need to contact your VAR for one of these Vault options.
Jarrod,
This Vault help file entry should be updated... It says Vault Basic supports Plant 3D.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi Scott,
Its a tough call on this. The AutoCAD Plant 3D application is supported on Vault Basic, but the AutoCAD Plant 3D project is not. You can use Vault basic for the dwg files only if you really wished, and also to xref files from other disciplines.
Hi Jarrod
So simple answer is, if Plant 3D is used as intended for projects it is not supported using Vault Basic!
Regards
Paul
Thats right Paul
