I would like to help me, every time I want to create a Plant 3D project with the Vault option I get the following warning ... attached image .... I hope I can support .... thanks
Solved by scottmoyse. Go to Solution.
this doesn't work with vault basic only with vault workgroup and higher
DarrenP
The Vault help file says Vault Basic supports Plant 3D.... I was surprised to read this, since I thought it only worked with paid versions of Vault:
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-334CC890-1F12-429C-9D6A-B964327CA590
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
dont belive this
vault are a killer ( so in the 2012 it coud not handel Plant more then one reson to let it be )
@cadwomen wrote:
dont belive this
Sorry? Can you elaborate please?
Scott Moyse
DarrenP
Scott Moyse
for 2012 Plant
use vault as it nessesery in a group , one member do a "check out" ( so a copy are on his laptop )
make a ckeck in so far everything fine
but 😉 the copy still on the laptop , he forget to dell manuel !! ( what a **** )
work on on the "copy" and vault check it in later ----- als the things ar gone , no one knows or ifen se what are going on
that was just one of the Big Bug´s
Plant self are not made for ( see Contens file on lokel maschine )
Catalog you have to copy .. and on and on
like i said 2012 ( dont think its better now because Plant still Plant )
cw
DarrenP
Scott Moyse
DarrenP
@DarrenP wrote:
this is how i learned about it from here
http://youtu.be/9_LAI0QNDWM
this is still the same for 2014 and 2015
according to the video vault workgroup or higher is required
Vault Basic is supported for non Project workflows.... not sure there are any useful non project workflows. Thanks to Jarrod for clarifying.
Scott Moyse
