AutoCAD Plant 3D General DIscussion
2 Kudos
Post 1 of 2
Valve Support - Tag Display and Component added to BOM
272 Views, 1 Replies
10-05-2011 06:02 AM
Hello again  :-) ,
I have the following questions regarding the valve supports:
  1. Is it possible to get the valve support tag displayed on the Isometrics togheter with its tag?
  2. Is it possible to obtain valve support in BOM (but as a different item / quantity and not together with the pipe support)?
I get the pipe support only but the valve support tag I add manually, using AutoCAD. I don't want to have the support tag integrated in the valve tag deffinition because, of course, not all valves have a support.
The creation of a tag with two lines which can adjust its size according to number of attributes filled in (not to have an empty space in the rectangle) will be also acceptable.
From the attachment you can see what I would like to get automatically from Isometrics, if possible.
I’m using Plant3D 2011 at the moment.
Thank you
Roxana
Valued Mentor
30 Kudos
Post 2 of 2
Re: Valve Support - Tag Display and Component added to BOM
10-23-2011 02:57 AM in reply to: Roxana-Elena
Hello Roxana-Elena!
Very good post. I have this issue too. No solved so far unfortunately. What we need is similar to a secondary pipe support.
I have put the question in the 2013 whishlist. Hope there will be an answer soon.
Best Regards!
Attila Vallyon
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
