AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Valve size callouts on control valves
6 REPLIES 6
eskisa0100
351 Views, 6 Replies
When I convert a valve to a control valve, the size callout, i.e. 2", is right in the middle of the stem.  Can anyone tell me if there is any way to move the size callout over to the side?
Thank you.
6 REPLIES 6
patpat79
in reply to: eskisa0100
can you attach snapshot so we can understand more of your question?? thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
eskisa0100
in reply to: patpat79
Please see attached picture. Hopefully this helps. Thank you.
patpat79
This query must be post in the P&ID section, but then, as to your question, you can just edit the "tag" block or create a new one which suits your need. As you can see, you are using the default Plant 3d tag block available in the software.
Best Regards,
Pat Andres
GHD Manila
eskisa0100
Thanks.  I created a new tag but I can't find a way to change it to that new tag after I have inserted the valve.  If I change it to that tag in the project properties, it will be like that for all ball valves.  I am looking for a way to be able to change it once it is already inserted - different tag for different acuators. Not sure if this is possible. I will repost on the P&ID forum.  Thank you again.  It's a start!
Scott.Hallmark
In Project Setup, go to where you created the new tag or annotation and in the left column, at the bottom, is "TagFormatName" and "AnnotationStyleName"  Set those to the newly created styles and try it again.
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
eskisa0100
in reply to: Scott.Hallmark
But like I said, if I change it there, it changes it for ALL the ball valves.  I only want that option when I make it into a control valve.
”Boost
