AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Using Plant 3D with Design Review
1 REPLY 1
frederixon
483 Views, 1 Reply
My company is using Plant 3D to model large tank farms. Is it possible to get the layers, valve and line tag information, etc. to show up in Design Review so people without access to Plant 3D can view them?
1 REPLY 1
gulnacm
in reply to: frederixon
Try using the Publish in Plant 3D project manager. right click on an opened Plant 3D model file in project manager. Choose publish on the fly out. The publish dialog will be invoked. Make sure to check the "3D DWF" box on the Model sheet. Once published the 3D object can be viewed in design viewer. There will be some data (tagging, description, etc.) will be seen in the Object Properties by choosing a Plant 3D object.
Hope this helps
Mike G (Autodesk)
Michael Gulnac
Technical Specialist
Organization
Autodesk, Inc.
”Boost
