Has anyone tried using any of the Offset valves in the Plant 3D Parametric Graphics/ValveBody section. Try as I might I can't get them to actually draw the port necks from the bodies.
If we can get this to work we will be on our way to using the product to model sanitary pipe systems.
Brian Lund
GEA Process Engineering, Inc.
If possible could you attach some screen captures of the representation of the valve you are needing to create.
Quentin Contreras
Technical Support Specialist
Quentin,
Thanks for the reply. Did you open a ticket on this? Someone from AutoDesk did but I haven't been contacted yet.
Any here are two graphics. The one on yellow is representative of the result I'm getting. No matter what I do I can't get the necks of the nozzles to show up. The attachements seem to work as you can see. the other graphic is what I would have expected it to look like.
Brian
Brian,
did you ever get answer to this question, I work on GEA dryer projects and need the same sanitary piping content to work for us.
thanks
Since you are GEA and so am I why don't you contact me off-line and we can talk.
