The ability to selected the Bolt & gasket types prior to running a line (maybe in the pipe insertion area of the ribbon) a couple of drops which list the different types of gasket & bolts within the current selected spec.
1) Legend for P&ID drawings
2) "P&ID Equipment List" similar like "P&ID Line List"
3) BOM for ORTHO drawing
4) Validation in 2012 version doesnt work corect, dont see error for situation when in P&ID we have 10 tanks, in Plant 3D we have 8 tanks, this is no problem for validation this is huge mistake
5) More plastic parts catalogs
6) Like someone says before when we take valves or pipe from "P&ID Line List" we dont have any information when we take the compnent again, i recomanded in next versions change the color or something information like "This valve is used in P3D now"
7) Pipe Support Editor, make we create new support like we create new equipment
😎 Two way connection beetwen AutoCAD Plant 3D and Inventor
9) Automatic upload specyfication from P&ID to Plant 3D, for example if we change diameter in P&ID from 100mm to 200mm Plant 3D automaticly changed this pipe
10) Simple generator from Steel Structure, or raport generator for steel structure for example lenght of Member etc.
