have created a model and am now running iso's off with welds, for some reason my welds are being doubled number so each individual weld has 2 calls off it (have checked model and there is only one weld dot at each weld location)
running plant 3d 2012
Can you please post the model here?
have found that if i change from buttweld to socketweld the issue goes away?
file size to large
"The attachment file size is too large. The maximum file size is: 1,572,864 bytes"
zipped file is 3,408kb
Ok, can you post the PCF file?
The PCF file is a text file that you could open up in Notepad. If you look at it and it has two welds at each connection, there is a problem with the model. If there is one weld per connection, then there is a problem with the iso.
In the first case, the model or at least this line from it will be needed to figure it out. If it's the second case, then just the PCF should be enough.
Thanks Peter for your reply , have been Private messaging Tomislav Golubovic about this and have sent hime some of the model & associated specs, were unable to find a solution to the problem but work around will have to do for this jobs timeframe.
Thanks again Tomislav for your quick response.
