AutoCAD Plant 3D General DIscussion
Member
AnandHarrypersad
Message 1 of 4 (205 Views)
Updating Specs retro activly
205 Views, 3 Replies
09-26-2012 11:04 AM
I have a nearly completed project and I need to modify the specifications for a specific class of fittings. After editing the catalogue and specs how can I update the out dated refferenced specs?
Thank you,
Henry
Valued Mentor
JohnHolder
Message 2 of 4 (199 Views)
Re: Updating Specs retro activly
09-26-2012 03:12 PM in reply to: AnandHarrypersad
an easy out would to be add the new spec under a different name, and use the new parts.  I have had to do this a couple times.  It does not work if you need to modify the old fittings in the drawing though.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Member
AnandHarrypersad
Message 3 of 4 (168 Views)
09-27-2012 10:59 AM in reply to: JohnHolder
Thanks, John.
I guess I'll be modifying the existing parts as required. I was hoping to escape that.
Valued Mentor
JohnHolder
Message 4 of 4 (166 Views)
09-27-2012 12:26 PM in reply to: AnandHarrypersad
Unfortunatly that has been my experience.. hopefully someone else can give us both good news 8(
Master Yoda.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
